Cool TV guide Picons
mika
Hi All
How can i get the picons on CoolTv guide 3.1.0 plugin, like on this picture ? Thanks.
Hi All
You have to active them in cool guide menu.
Try to press menu botton when cool guide is active and look for something about picons.
here is the menu:
cool 3D = standard
load picon=yes
load cool=yes
cool easy guide+coolpic=yes
start with standard=yes
picon height=60
picon item height=60
cool pico height=30
cool pico item=30
left width60=110
leftwidth70=190
channel at start=non
picon path=/user/shar/...etc
here is the menu:
cool 3D = standard
load picon=yes
load cool=yes
picon height=60
cool pico height=30
cool pico item=30
left width60=110
leftwidth70=190
I think the problem is into the picon path. The path of picons is /media/usb/picons :)
In the menu of cooltv guide it´s like this :
Picon Path(press menu)= /user/share/dvbpp2/picon
Can you change the picon path ? If you can change it, set to /media/usb/picon and the plugin can find the picons already installed into your USB stick.
I can´t install Picons in CoolTV? I have Glass HD skin. In Cool TV Guide setup, I don´t found Picon Path.
