Cool Tv Guide V.4.0.0 by Coolman
Tamaki
Here is v.4 of Cool tv Guide.
green = all channels are now running
light blue = channel is selected
blue = all channels
red = recording
"Pad"
2 page high
8 page down
4 page left
6 page right
and switch on and zapping channels without EPG! (Adjustable)
Pad to sew, as usual
Reset to 5
Full Reset to 0
1 Zoom in
3 Zoom out
7 switching between 4 Guides (adjustable)
Switch 9 to 20 clock
<Day - ( Guide -dependent)
> Day + ( Guide -dependent)
red = Zap (adjustable)
langrot = Zap + exit (adjustable)
green = timer (adjustable + edited)
= Green for shipment automatically add the Auto Timer (adjustable)
yellow = cool switch (adjustable)
long yellow bouquet = list (set)
blue = cool search function (adjustable)
Do you search long blue = function (adjustable)
OK = Cool Info Guide (adjustable)
langOK = (adjustable)
Rec = QuickRec
kurzEPG / Info = Guide Select (zap through all the guides)
langEPG / Info = CoolTVGuide <> cool multi guide
HELP = Display all commands
Setup menu =
TV = Timer List
Power = Off Timer
3D view / default view (selectable)
/ Usr/lib/enigma2/python/Plugins/Extensions/CoolTVGuide/Cool3D /
it has 2 folders
Standard (default view)
MyDesign (for your self-made designer)
Skindesigner the folder is directly in the skin
eg / usr/share/enigma2/BlackAlu-Coolman-Mod/SkinDesign /
Thus can now make each person has their own look and easy buttons
Cool TV Guide , Cool Tiny Guide , Cool Multi Guide , Cool Nice Guide , Cool Info Guide , Cool Single Guide , Cool Easy Guide , cool search and setup
were stored in on extra CoolSkin folder ...
Thus, you can now change the Skinns without restarting
I also made notes for Skinner, so you can install it easily
The setup:
You can now show your own buttons ...
since there never was in agreement
Height for your Picon adjustable!
Thus you can determine your own cell height and frame
and you can even left the distances and the number of your Picon see the set you want!
genaus as Picon on and off!
start on channel 1 (adjustable)
Prime Time for example 20:15 (adjustable)
Font size, columns, even the time-line are all set!
Home screen can be selected! Choose a simple switch to Cool or 7 what do you want to have ..
Display of the bouquet in the Skin
Bouquets who has to be just as happy about the setup ...
set is the bouquet display at Start On / Off
but I think it is more practical to put his bouquets on a button ...
since the plugin anyway noted the position and the bouquet ...
Standard Picon folder:
/ Usr/share/enigma2/picon /
Standard CoolPico (Mini-Picon) folder:
/ Usr/share/enigma2/picon/coolpico /
You can then choose any other place for your Picon / Coolpico
although the coolpico picon folder in the folder must always be
In your setup, It refers to your new PICON FOLDER
NOT the CoolPico .. but only the PICON FOLDER!
(The coolpico is Displayed automatically)
Therefore the setup must stand as
or
/ Mnt / usb / picon /
etc
super cool is the cool search function ...
Missed .. or already started?
no problem .. press the blue button and you see directly where a repeat run Just!
or you go into the Cool Info Guide ,
there you have the new CoolSimilar
that shows you for each shipment Whether it is sent somewhere again
who joined his box and the Internet will look forward to Do
but you still have to adjust your load on the contact feed ...
Timer alarm!
This feature is brand new and has no other EPG
It checked out your timer recording ...
images are moved through the channel, but are still in time to be cut without,
then the recording remains red
But the recording is cut, then the display is yellow!
Sun even if you see a yellow recording, then it is high time to review it!
have fun with it!
come from the CoolPico Littleleo's Black 3D Button Picon
for me the most beautiful
Instructions:
copy the ipk to the TMP and how to install all plugins ...
Attention at the request of many users:
Cool TV Guide is not in the plugin folder!
So not to see enhancements ...
it is called, In Which you the info / EPG button pressed for long ...
but would Encourage anyone to install the multi Quickbutton plugin ...
Thus, you can then eg Cool TV Guide the red buttom eg call directly with
Picon / CoolPico:
since there are always problems
attached out my default Picon (Littleleo's Black 3D Button Picon)
complete with CoolPico
Just copy the box on your path to choose and it runs Picon
Note:
requires only the enigma2-plugin-extensions-cooltvguide_Coolman_V4.0.0_all.ipk
only those who want to have the design ...
Which must be the enigma2-plugin-extensions-cooltvguideskin_Coolman_V4.0_all.ipk
Here are some shoots.
I have been using Cooltv since version 2 and it has been quite stable. However I have had a couple of crashes on that version 4.0, which I never had before.
have you got any crash Tamaki?
Cheers
Cheers
Had one crash once only , it happened @ a skin I was testing, but made re-install of Cool Tv and every things are fine now!
Cheers
No, i didn't have any crashes for now.
What did you do when crashed?
Nothing special, just opened the guide and it crashed. Another time, opened the guide and the whole mutligraph was blank, not channel on left and no EPG, crashed again.
Crash attached
Crash attached
I red your crash, but i didn't understand what's the problem.
Try to reload new settings, and try to check your epg config.
And what about skin? Are you using a default one?
Which img?
Here is the part of your crashlog, maybe someone more expert can help:
eListboxPythonMultiContent: error getting item 0
eListboxPythonMultiContent: error getting item 1
eListboxPythonMultiContent: error getting item 2
eListboxPythonMultiContent: error getting item 3
eListboxPythonMultiContent: error getting item 4
eListboxPythonMultiContent: error getting item 5
File "/usr/lib/enigma2/python/Plugins/Extensions/CoolTVGuide/plugin.py", line 327, in serviceChanged
File "/usr/lib/enigma2/python/Plugins/Extensions/CoolTVGuide/plugin.py", line 338, in findBestEvent
File "/usr/lib/enigma2/python/Plugins/Extensions/CoolTVGuide/plugin.py", line 609, in buildEntry
AttributeError: 'NoneType' object has no attribute 'toString'
(PyObject_CallObject(<bound method CoolEPGList.serviceChanged of <Plugins.Extensions.CoolTVGuide.plugin.CoolEPGList object at 0xcacd50>>,()) failed)
main thread is non-idle! display spinner!
</enigma2crashlog>
just put new blackhole image on duo now everytime i try to look at epg via cooltv guide 4.0 it keeps crashing now
Which img?
Flashed 1.6.5 yesterday and reinstalled all my plugins so will monitor if any problem.
Cheers
I believe that I have asked some questions around Cool TV Guide that are probably more suited in this posting - The post is
29021 - Am I better to leave as is or copy/delete the content from that post to this ?
Thanks
Thanks
Yes, copy and paste here.
Hi All
Within Cool TV Guide setup I have mapped the OK button to Zap + Exit. When I am within the Guide if I go to a channel and move forward to a time beyond the current program , press ok , the Zap and Exit function is executed - Can there be an option to prompt for 'Add Timer' 'Do Nothing' or Info under these conditions ? rather than the execution of the Zap and exit ?
Is there a way that I can rename certain attributes - For example rename 'Bouquetlist' to 'All Listings'
Is there a way from within Cool TV Guide of accessing the Timer List? If not is there a way from a single button that I can access the Timer List?
I have mapped the quick record function to the red button within Cool TV. When in the program guide I execute this function the recording of the program starts as I would expect. I do not get an option to stop recording the program, if I use the red button again the progam sometimes stops recording, soemtimes does not. If I use the Add Timer function to start a recording, I then get a Timer edit button, allowing me to stop/cancel the recording.
Is this a problem within Cool TV Guide?
'Is there a way from within Cool TV Guide of accessing the Timer List? If not is there a way from a single button that I can access the Timer List?'
So I understand that the TV button will bring up the Timer List - so can I create a button label on the Program Guide for Timer List and execute the command TV within the keymap?
