CoolTv Guide Ver 7.3 error Messege.
I had previously installed 7.3 which brings ceased operations. I removed it and installed that version 7.6. All was going well, no errors. But the cool TV Guide, does not show anywhere? Would it be tips on how to get it running again?
die aktuelle version
Hi,
I have downloaded your version and copied the ipk file to /tmp.
But when I go on "install manually ipk" on the menu, the system comes back saying "there is nothing to install in /tmp" ....
What am I missing ?
Thx,
GS
leider kann ich kaum englisch, du musst diese version http://www.vuplus-community.net/boa...ons-cooltvguide_coolman_v7-6-0_all-ipk.29529/ nur in den Tmp ordner kopieren dann grüne taste / gelbe taste ( addons) / manuell install ipk packges gehen und installieren lassen , mehr nicht
funktioniert super
gruß
Danke, I habe vergessen /tmp ist eine volatile memory ... Thanks, I had forgotten /tmp is a volatile place, there was a shutdown/reboot between the time I initially copied the file and when I went back on the screen menu to install the ipk. Did it again and now it works OK - Thanks.
GS
@bodo1960 I guss you have a method to fix the coolTV guide issues. Please offer an english instruction and download place. I got lost from the above conversation.
Or anyone can offer an englidh translation?
Hey, I may not Cool TV Guide v7.6 to work.
Key?
where do you find the key number?
this is a paid app, or?
it should not just be freeware on this forum?
So happy this is working again. Working perfectly on BH 3.0.3C. And because it includes the configuration options (BH Plugins->CoolTVGuide Configuration ->yellow button ("TV") -> changing the red button option to "yes" then -> red (save) -> then restart box, I only need to press the red button to get CoolTVGuide on my screen. Thankyou Bodo !
