Couple noob questions
01342
Hi,
I have a couple of questions (for now). Just got a Solo2.
What is meoboot?
What's a good bouquet (sky-ish) for black hole?
How do I install a bouquet?
Cheers,
Keith
meoboot:
http://www.vuplus-community.net/board/threads/meoboot-·-short-user-guide.1899/
try couple of bouquets from BH feed and you'll find yourself which one fits you
to transfer channel list to your box use dreamset or dreamboxedit
everything is here:
http://www.vuplus-community.net/board/forums/black-hole-howto.93/
Thanks, but the meoboot link tells how to install it, not what it does and the link to how to just lists 5 pages of threads. I've been through those ( not read each one obviously) and I can't find any thread that links to any bouquet that I can try. Doesn't BH have an auto bouquet like Vix? I wanted to try BH cos Vix crashed by Solo2 one too many times but I can't even get past flashing BH to the solo.
Cheers,
Keith.
Thanks again, I'm really struggling here, BH seems less user friendly than Vix but, as I said, Vix has crashed my Solo to much.
Is there an idiot guide somewhere? I have searched but most of what I find isn't even in English.
For example, I went green yellow online feeds and all I see is a list of things that mean nothing to me, I did install the first one but Christ knows what that's done. It's all double Dutch to me.
don't worry too much, it's so easy and user friendly. Couple of hours and you'll find out how to use it. It was exactly the same with your first PC, wasn't it?;) Or with first car...
Read 'BH how to' thread, reinstall image, mount your drive and usb, perform online update to version 2.0.1a (green > yellow > online black hole image update, then follow instruction on the screen). Then extend your flash and use swap for memory. All these things you'll find in the thread mentioned above (BH how to..)
That's the way you need to start from...
Thanks again. I've looked again at the how to's. not one thread on how to load/ install a bouquet. I've literally spent hours on this and all I want to do is watch some telly. The enemy is on my case and I don't see why this had to be do complicated, it was certainly easier getting to watch telly with Vix. So, defeated, I'm going to install Vix again and see if it'll go more than a few days before it throws another wobbly :(
I've already written above where you need to start from. If you have more questions - just ask, don't be shy ;)
And believe me it's so easy - well, a bit more complicated than sky box cause you need to install everything by yourself.
And remember you can always come back here and you'll be very welcome :)
Good luck
Still here. Still struggling:)
I'm gonna try to re flash BH then DBE a bouquet to the Solo.
Just thinking out loud :)
Hi
Sorry to hear you're having a hard time, the positive news is that you're so close now it's worth pushing on as the good stuff is on the other side :)
If it helps here's the sat.xml I use on my sky fixed dish setup
Take a look at
http://www.vuplus-community.net/board/threads/bh-2-0-1-autobouquets-autotimer.11353/#post-82273
and then install the one of the auto bouquet makers from :
http://www.vuplus-community.net/board/threads/bh-2-0-1-autobouquets-autotimer.11353/#post-83470
http://www.vuplus-community.net/board/threads/autobouquetsmaker-oe-alliance.10031/page-2#post-83494
That should get you up and going
