Crash trying to access info panel
rurs
I'm not sure where is the best place to post crash logs?
Anyway, twice now vu+ has crashed to green screen when going to info panel.
The panel shows, but none of the meters/dials have any info, then box crashes.
It is difficult to determine the cause of your problem
I think this problem was not when you first time installed image
Maybe your flash is full or you installed an additional plugin, etc.
Try to remove some plugin or some skin
and if does not help, I think it's best to install image agn.
In any case I do not have this problem.
Using default BH skin, only extra plugin is QuickButton...maybe this is cause, as it uses colour buttons?
Anyway, not happening now, maybe just a strange anomaly
So this is best thread to post crashlogs?
Thanks
Anyway, not happening now, maybe just a strange anomaly:)
Thanks
It is fine to post crashlog here like you have, sometimes I have had a similar crash as you describe and I can find no reason. It normally happens when the box has been running for 3 or more days without a reboot with me.
If you have problem with image always test first with a clean image
so we can trace the problem, and you have to post crashlogs.
Rgd MX
