Crash with blue panel OBH4. 4
mccann007
Vu solo2
93.8413> 16:33:57.9224 [ActionMap] Keymap 'OkCancelActions' -> Action = 'ok'.
<    93.8666> 16:33:57.9477 Traceback (most recent call last):
<    93.8667> 16:33:57.9478   File "/usr/lib/enigma2/python/Components/ActionMap.py", line 57, in action
<    93.8673> 16:33:57.9484   File "/usr/lib/enigma2/python/Screens/BpBlue.py", line 169, in keyOk
<    93.8677> 16:33:57.9489   File "/usr/lib/enigma2/python/Screens/BpBlue.py", line 178, in sendtoBh_sock
<    93.8681> 16:33:57.9493   File "/usr/lib/python2.7/socket.py", line 228, in meth
<    93.8689> 16:33:57.9501 socket.error: [Errno 146] Connection refused
<    93.8692> 16:33:57.9504 [ePyObject] (CallObject(<bound method ActionMap.action of <Components.ActionMap.ActionMap instance at 0x702adbe8>>,('OkCancelActions', 'ok')) failed)
I can't reply this crash.
Please tell us more details:
1) is it your image installed in flash or in OMB?
2) What did you exactly did after entering the blue panel? Did you choose one of the subsections or directly pressed EXIT?
The image is in multiboot, Blackhole in flash
When I press OK common interface, it crashes.. Nothing else installed.
Well: no crash from flash, then. As soon as possible I'll try from OMB, too, but I suspect there's a problem in your installed image, only.
But, I've got OBH also in flash: so my try can't reproduce exactly your case.
You don't say which build of obh 4.4 you are using.
Try doing an online update, and if that doesn't fix it, then something is corrupt in your image, so you will need to reflash / reinstall the image in OMB.
it is 4.4.023
I installed in Flash, no problem , but When installed in multiboot , there is the crash
it is 4.4.023
something did not update then when in omb, or the image was corrupted.
Working fine here on 12 different boxes some in flash some in omb
After several testing,OBH 4.4.017 ( Fresh install) , no crash
after online update to 4.4.023 , start crashing.
Is there up to date OBH 4.4.023 on website here? so I do not need to do online update , the one here is 4.4.013
