forest
E' da oggi che la 173 che ho in flash mi va in crash, succede quando scorro la lista canali, uso BH173 in flash, setting Vhannibal, skin di default nexGenHD Gradient Army, ho copiato il crashlog con la speranza di riuscire a trovare ciò che mi causa il crash:
version="1.0" encoding="utf-8"?>
<opendreambox>
<enigma2>
<crashdate>Sat May 12 01:44:30 2012</crashdate>
<compiledate>Apr 8 2012</compiledate>
<contactemail>crashlog</contactemail>
<skin>skin.xml</skin>
<sourcedate>Apr 8 2012</sourcedate>
<branch>vuplus_experimental</branch>
<rev></rev>
<version></version>
</enigma2>
<image>
<dreamboxmodel>dm500hd</dreamboxmodel>
<kernelcmdline>bmem=112M ubi.mtd=0 root=ubi0:rootfs rootfstype=ubifs rw rootflags=sync</kernelcmdline>
<imageversion>
<![CDATA[
version=1000201204082224
comment=Vuplus
target=9
creator=OpenEmbedded <oe@vuplus.com>
url=http://www.vuplus.com/
catalog=http://www.vuplus.com/
</imageversion>
<imageissue>
<![CDATA[
Vuplus 2.2.0 + BlackHole 1.7.3 %h
</imageissue>
</image>
<software>
<enigma2software>
<!-- Cannot allocate memory -->
</enigma2software>
<dreamboxsoftware>
</dreamboxsoftware>
<gstreamersoftware>
</gstreamersoftware>
</software>
<crashlogs>
<enigma2crashlog>
<![CDATA[
id 2d51
no version filtering
0451: 02 2d 51 00 00 00
mask: ff ff ff 00 00 00
mode: 00 00 00 00 00 00
doing version filtering
0000: 00 00 00 03 00 00
mask: ff 00 00 3f 00 00
mode: 00 00 00 3e 00 00
+ 1/1 TID 02
done!
RECORD service event 5
start streaming...
[eDVBCAService] add demux 0 to slot 0 service 1:0:1:2D51:170C:FBFF:820000:0:0:0:
[eDVBCIInterfaces] gotPMT
demux 0 mask 01 prevhash 04510103
[eDVBCAService] don't build/send the same CA PMT twice
0451: 02 2d 51 07 00 00
mask: ff ff ff 3f 00 00
+- 1/2 TID 4e
++ 2/2 TID 4e
done!
[eDVBServiceRecord] now running: †Godi nel c... Vol.2 (Trans)‡ (6600 seconds)
0012: 4e 2d 51 21 00 00
stop recording!
[eDVBServiceRecord] saving cutlist failed because tstools failed
[eDVBCAService] free slot 0 demux 0 for service 1:0:1:2D51:170C:FBFF:820000:0:0:0:
Unhandled error in Deferred:
Failure: twisted.internet.error.ConnectionDone: Connection was closed cleanly.
recording service: <enigma.eServiceReference; proxy of <Swig Object of type 'eServiceReference *' at 0x1d368c0> >
record: 0
allocate channel.. 170c:fbff
available channel.. 170c:fbff
found shared channel..
allocate Channel: res 0
[eDVBCIInterfaces] addPMTHandler 1:0:1:2D51:170C:FBFF:820000:0:0:0:
RECORD service event 6
tuned..
0012: 4e 2d 51 00 00 00
ok ... now we start!!
0000: 00 00 00 00 00 00
mask: ff 00 00 00 00 00
resolve: resolve ${sysconfdir}/scan_tp_valid_check.py
resolve: -> /etc/scan_tp_valid_check.py
start streaming...
+ 1/1 TID 00
done!
PATready
use pmtpid 0451 for service_id 2d51
+ 1/1 TID 02
done!
start streaming...
+- 1/2 TID 4e
++ 2/2 TID 4e
done!
nr_read 480 nr_write 3844
sum 4324 prev_sum 4187
hdd was accessed since previous check!
[IDLE] 0 600 False
stop recording!
[OpenWebif] page '/web/stream.m3u?ref=1:0:1:35C3:1388:13E:820000:0:0:0:&name=SCT%205' ok (custom)
[EPGC] start cleanloop
[EPGC] stop cleanloop
[EPGC] 18955772 bytes for cache used
record: 0
allocate channel.. 1388:013e
available channel.. 0001:013e
opening frontend 1
[eDVBCAService] new channel 0x1cb16f8!
(1)tune
RotorCmd ffffffff, lastRotorCmd ffffffff
prepare_sat System 0 Freq 11727000 Pol 1 SR 27500000 INV 2 FEC 3 orbpos 130 system 0 modulation 1 pilot 2, rolloff 0
tuning to 1127 mhz
OURSTATE: tuning
[eDVBCIInterfaces] addPMTHandler 1:0:1:35C3:1388:13E:820000:0:0:0:
allocate demux
[SEC] set static current limiting
set sequence pos 3
set sequence pos 4
[SEC] setVoltage 1
[SEC] sleep 200ms
[SEC] invalidate current switch params
[SEC] sendDiseqc: e00000(DiSEqC reset)
[SEC] sleep 50ms
[SEC] sendDiseqc: e00003(DiSEqC peripherial power on)
[SEC] sleep 150ms
[SEC] sendDiseqc: e01038f1
[SEC] sleep 50ms
set sequence pos 3
[SEC] setTone 1
[SEC] sleep 10ms
[SEC] update current switch params
[SEC] startTuneTimeout 5000
[SEC] setFrontend 1
setting frontend 1
[SEC] sleep 500ms
(1)fe event: status 0, inversion off, m_tuning 1
[SEC] set dynamic current limiting
OURSTATE: lost lock, trying to retune
(1)tune
tuning to 1127 mhz
OURSTATE: tuning
[SEC] setTone 0
[SEC] sleep 25ms
set sequence pos 7
[SEC] sleep 50ms
[SEC] sleep 150ms
[SEC] sleep 50ms
set sequence pos 3
[SEC] setTone 1
[SEC] sleep 10ms
[SEC] setFrontend 1
setting frontend 1
[SEC] sleep 500ms
stop recording!
(was not recording)
start release channel timer
(1)tune
tuning to 1127 mhz
OURSTATE: tuning
[SEC] setTone 0
[SEC] sleep 25ms
set sequence pos 7
[SEC] sleep 50ms
[SEC] sleep 150ms
[SEC] sleep 50ms
set sequence pos 3
[SEC] setTone 1
[SEC] sleep 10ms
[SEC] setFrontend 1
setting frontend 1
[SEC] sleep 500ms
release cached channel (timer timeout)
[eDVBCAService] remove channel 0x1cb16f8
[eDVBLocalTimerHandler] remove channel 0x1cb16f8
[eEPGCache] remove channel 0x1cb16f8
stop release channel timer
recording service: <enigma.eServiceReference; proxy of <Swig Object of type 'eServiceReference *' at 0x1d36e00> >
record: 0
(1)tune
tuning to 1127 mhz
allocate demux
set sequence pos 3
set sequence pos 3
[SEC] setFrontend 1
setting frontend 1
[SEC] sleep 500ms
(1)tune
tuning to 1127 mhz
OURSTATE: tuning
[SEC] setTone 0
[SEC] sleep 25ms
set sequence pos 7
[SEC] sleep 50ms
[SEC] sleep 150ms
[SEC] sleep 50ms
set sequence pos 3
[SEC] setTone 1
[SEC] sleep 10ms
[SEC] setFrontend 1
setting frontend 1
[SEC] sleep 500ms
(1)tune
tuning to 1127 mhz
OURSTATE: tuning
[SEC] setTone 0
[SEC] sleep 25ms
set sequence pos 7
[SEC] sleep 50ms
[SEC] sleep 150ms
[SEC] sleep 50ms
set sequence pos 3
[SEC] setTone 1
[SEC] sleep 10ms
[SEC] setFrontend 1
setting frontend 1
[SEC] sleep 500ms
(1)tune
tuning to 1127 mhz
OURSTATE: tuning
[SEC] setTone 0
[SEC] sleep 25ms
set sequence pos 7
[SEC] sleep 50ms
[SEC] sleep 150ms
[SEC] sleep 50ms
set sequence pos 3
[SEC] setTone 1
[SEC] sleep 10ms
[SEC] setFrontend 1
setting frontend 1
[SEC] sleep 500ms
(1)tune
tuning to 1127 mhz
OURSTATE: tuning
[SEC] setTone 0
[SEC] sleep 25ms
set sequence pos 7
[SEC] sleep 50ms
[SEC] sleep 150ms
[SEC] sleep 50ms
set sequence pos 3
[SEC] setTone 1
[SEC] sleep 10ms
[SEC] setFrontend 1
setting frontend 1
[SEC] sleep 500ms
(1)tune
tuning to 1127 mhz
OURSTATE: tuning
[SEC] setTone 0
[SEC] sleep 25ms
set sequence pos 7
[SEC] sleep 50ms
[SEC] sleep 150ms
action -> InfobarShowHideActions toggleShow
[SEC] sleep 50ms
set sequence pos 3
[SEC] setTone 1
[SEC] sleep 10ms
[SEC] setFrontend 1
setting frontend 1
[SEC] sleep 500ms
action -> InfobarChannelSelection switchChannelDown
reused converter!
reused converter!
reused converter!
reused converter!
nr_read 489 nr_write 3986
sum 4475 prev_sum 4324
[IDLE] 0 600 False
It's now Sat May 12 01:44:18 2012
next real activation is Sat May 12 09:09:40 2012
[timer.py] next activation: 1336779958 (in 99996 ms)
stop recording!
(was not recording)
recording service: <enigma.eServiceReference; proxy of <Swig Object of type 'eServiceReference *' at 0x1d52140> >
record: 0
use cached_channel
[eDVBCAService] channel 0x1cb16f8 running
[eDVBLocalTimerHandler] channel 0x1cb16f8 running
0014: 70 00 00 00 00 00
mask: fc 00 00 00 00 00
[eEPGCache] channel 0x1cb16f8 running
[EPGC] next update in 2 sec
tuned..
0012: 4e 35 c3 00 00 00
start streaming...
[EPGC] start caching events(1336779861)
(1)tune
tuning to 1127 mhz
OURSTATE: tuning
[SEC] setTone 0
[SEC] sleep 25ms
set sequence pos 7
[SEC] sleep 50ms
[SEC] sleep 150ms
[SEC] sleep 50ms
set sequence pos 3
[SEC] setTone 1
[SEC] sleep 10ms
[SEC] setFrontend 1
setting frontend 1
[SEC] sleep 500ms
timeout 0012!
(1)tune
tuning to 1127 mhz
OURSTATE: tuning
[SEC] setTone 0
[SEC] sleep 25ms
set sequence pos 7
[SEC] sleep 50ms
[SEC] sleep 150ms
[SEC] sleep 50ms
set sequence pos 3
[SEC] setTone 1
[SEC] sleep 10ms
[SEC] setFrontend 1
setting frontend 1
[SEC] sleep 500ms
It's now Sat May 12 01:44:28 2012
[timer.py] next activation: 1336779968 (in 99996 ms)
[EPGC] abort non avail nownext reading
[EPGC] abort non avail schedule reading
[EPGC] abort non avail schedule other reading
[EPGC] abort non avail viasat reading
[EPGC] abort non avail mhw reading
stop recording!
recording service: <enigma.eServiceReference; proxy of <Swig Object of type 'eServiceReference *' at 0x1d522c0> >
record: 0
use cached_channel
tuned..
start streaming...
FATAL: epgcache.cpp:150 ASSERTION pos <= 4108 FAILED!
</enigma2crashlog>
<pythonMD5sum>
</pythonMD5sum>
</crashlogs>
</opendreambox>
