File "/usr/lib/enigma2/python/Components/ActionMap.py", line 46, in action
res = self.actions[action]()
File "/usr/lib/enigma2/python/Plugins/Extensions/TSmedia/plugin.py", line 443, in KeyOk
File "/usr/lib/enigma2/python/mytest.py", line 312, in open
dlg = self.current_dialog = self.instantiateDialog(screen, *arguments, **kwargs)
File "/usr/lib/enigma2/python/mytest.py", line 247, in instantiateDialog
return self.doInstantiateDialog(screen, arguments, kwargs, self.desktop)
File "/usr/lib/enigma2/python/mytest.py", line 278, in doInstantiateDialog
dlg.applySkin()
File "/usr/lib/enigma2/python/Components/GUISkin.py", line 112, in applySkin
self.createGUIScreen(self.instance, self.desktop)
File "/usr/lib/enigma2/python/Components/GUISkin.py", line 41, in createGUIScreen
applyAllAttributes(w.instance, desktop, w.skinAttributes, self.scale)
File "/usr/lib/enigma2/python/skin.py", line 291, in applyAllAttributes
applySingleAttribute(guiObject, desktop, attrib, value, scale)
File "/usr/lib/enigma2/python/skin.py", line 191, in applySingleAttribute
ptr = loadPixmap(value, desktop) # this should already have been filename-resolved.
File "/usr/lib/enigma2/python/skin.py", line 170, in loadPixmap
raise SkinError("pixmap file %s not found!" % (path))
skin.SkinError: {skin.xml}: pixmap file /usr/lib/enigma2/python/Plugins/Extensions/TSmedia/interface/img/frame3.png not found!
(PyObject_CallObject(<bound method ActionMap.action of <Components.ActionMap.ActionMap instance at 0x1c93968>>,('OkCancelActions', 'ok')) failed)
File "/usr/lib/enigma2/python/Plugins/Extensions/TSmedia/addons/movies/fullstream/plugin.py", line 634, in keyOK
File "/usr/lib/enigma2/python/Plugins/Extensions/TSmedia/addons/movies/fullstream/plugin.py", line 570, in get_stream
AttributeError: 'TSmediaservers' object has no attribute 'hostname'
And... properly install your "disk",
['\n']
['Disk /dev/mtdblock0: 235 MB, 235929600 bytes\n', 'Disk /dev/mtdblock0: 235 MB, 235929600 bytes\n', 'Disk /dev/mtdblock0: 235 MB, 235929600 bytes\n', 'Disk /dev/mtdblock0: 235 MB, 235929600 bytes\n', 'Disk /dev/mtdblock0: 235 MB, 235929600 bytes\n', 'Disk /dev/mtdblock0: 235 MB, 235929600 bytes\n']
['255 heads, 63 sectors/track, 28 cylinders\n', '255 heads, 63 sectors/track, 28 cylinders\n', '255 heads, 63 sectors/track, 28 cylinders\n', '255 heads, 63 sectors/track, 28 cylinders\n', '255 heads, 63 sectors/track, 28 cylinders\n', '255 heads, 63 sectors/track, 28 cylinders\n']
['Units = cylinders of 16065 * 512 = 8225280 bytes\n', 'Units = cylinders of 16065 * 512 = 8225280 bytes\n', 'Units = cylinders of 16065 * 512 = 8225280 bytes\n', 'Units = cylinders of 16065 * 512 = 8225280 bytes\n', 'Units = cylinders of 16065 * 512 = 8225280 bytes\n', 'Units = cylinders of 16065 * 512 = 8225280 bytes\n', 'Units = cylinders of 16065 * 512 = 8225280 bytes\n', 'Units = cylinders of 16065 * 512 = 8225280 bytes\n', 'Units = cylinders of 16065 * 512 = 8225280 bytes\n', 'Units = cylinders of 16065 * 512 = 8225280 bytes\n']
['\n']
["Disk /dev/mtdblock0 doesn't contain a valid partition table\n", "Disk /dev/mtdblock0 doesn't contain a valid partition table\n", "Disk /dev/mtdblock0 doesn't contain a valid partition table\n", "Disk /dev/mtdblock0 doesn't contain a valid partition table\n", "Disk /dev/mtdblock0 doesn't contain a valid partition table\n", "Disk /dev/mtdblock0 doesn't contain a valid partition table\n", "Disk /dev/mtdblock0 doesn't contain a valid partition table\n", "Disk /dev/mtdblock0 doesn't contain a valid partition table\n"]
['\n']
['Disk /dev/mtdblock1: 235 MB, 235929600 bytes\n', 'Disk /dev/mtdblock1: 235 MB, 235929600 bytes\n', 'Disk /dev/mtdblock1: 235 MB, 235929600 bytes\n', 'Disk /dev/mtdblock1: 235 MB, 235929600 bytes\n', 'Disk /dev/mtdblock1: 235 MB, 235929600 bytes\n', 'Disk /dev/mtdblock1: 235 MB, 235929600 bytes\n']
['\n']
["Disk /dev/mtdblock1 doesn't contain a valid partition table\n", "Disk /dev/mtdblock1 doesn't contain a valid partition table\n", "Disk /dev/mtdblock1 doesn't contain a valid partition table\n", "Disk /dev/mtdblock1 doesn't contain a valid partition table\n", "Disk /dev/mtdblock1 doesn't contain a valid partition table\n", "Disk /dev/mtdblock1 doesn't contain a valid partition table\n", "Disk /dev/mtdblock1 doesn't contain a valid partition table\n", "Disk /dev/mtdblock1 doesn't contain a valid partition table\n"]
['\n']
['Disk /dev/mtdblock2: 7 MB, 7340032 bytes\n', 'Disk /dev/mtdblock2: 7 MB, 7340032 bytes\n', 'Disk /dev/mtdblock2: 7 MB, 7340032 bytes\n', 'Disk /dev/mtdblock2: 7 MB, 7340032 bytes\n', 'Disk /dev/mtdblock2: 7 MB, 7340032 bytes\n', 'Disk /dev/mtdblock2: 7 MB, 7340032 bytes\n']
['255 heads, 63 sectors/track, 0 cylinders\n', '255 heads, 63 sectors/track, 0 cylinders\n', '255 heads, 63 sectors/track, 0 cylinders\n', '255 heads, 63 sectors/track, 0 cylinders\n', '255 heads, 63 sectors/track, 0 cylinders\n', '255 heads, 63 sectors/track, 0 cylinders\n']
['\n']
["Disk /dev/mtdblock2 doesn't contain a valid partition table\n", "Disk /dev/mtdblock2 doesn't contain a valid partition table\n", "Disk /dev/mtdblock2 doesn't contain a valid partition table\n", "Disk /dev/mtdblock2 doesn't contain a valid partition table\n", "Disk /dev/mtdblock2 doesn't contain a valid partition table\n", "Disk /dev/mtdblock2 doesn't contain a valid partition table\n", "Disk /dev/mtdblock2 doesn't contain a valid partition table\n", "Disk /dev/mtdblock2 doesn't contain a valid partition table\n"]
['\n']
['Disk /dev/mtdblock3: 1 MB, 1048576 bytes\n', 'Disk /dev/mtdblock3: 1 MB, 1048576 bytes\n', 'Disk /dev/mtdblock3: 1 MB, 1048576 bytes\n', 'Disk /dev/mtdblock3: 1 MB, 1048576 bytes\n', 'Disk /dev/mtdblock3: 1 MB, 1048576 bytes\n', 'Disk /dev/mtdblock3: 1 MB, 1048576 bytes\n']
['\n']
["Disk /dev/mtdblock3 doesn't contain a valid partition table\n", "Disk /dev/mtdblock3 doesn't contain a valid partition table\n", "Disk /dev/mtdblock3 doesn't contain a valid partition table\n", "Disk /dev/mtdblock3 doesn't contain a valid partition table\n", "Disk /dev/mtdblock3 doesn't contain a valid partition table\n", "Disk /dev/mtdblock3 doesn't contain a valid partition table\n", "Disk /dev/mtdblock3 doesn't contain a valid partition table\n", "Disk /dev/mtdblock3 doesn't contain a valid partition table\n"]
['\n']
['Disk /dev/sda: 7927 MB, 7927234560 bytes\n', 'Disk /dev/sda: 7927 MB, 7927234560 bytes\n', 'Disk /dev/sda: 7927 MB, 7927234560 bytes\n', 'Disk /dev/sda: 7927 MB, 7927234560 bytes\n', 'Disk /dev/sda: 7927 MB, 7927234560 bytes\n', 'Disk /dev/sda: 7927 MB, 7927234560 bytes\n']
['64 heads, 32 sectors/track, 7560 cylinders\n', '64 heads, 32 sectors/track, 7560 cylinders\n', '64 heads, 32 sectors/track, 7560 cylinders\n', '64 heads, 32 sectors/track, 7560 cylinders\n', '64 heads, 32 sectors/track, 7560 cylinders\n', '64 heads, 32 sectors/track, 7560 cylinders\n']
['Units = cylinders of 2048 * 512 = 1048576 bytes\n', 'Units = cylinders of 2048 * 512 = 1048576 bytes\n', 'Units = cylinders of 2048 * 512 = 1048576 bytes\n', 'Units = cylinders of 2048 * 512 = 1048576 bytes\n', 'Units = cylinders of 2048 * 512 = 1048576 bytes\n', 'Units = cylinders of 2048 * 512 = 1048576 bytes\n', 'Units = cylinders of 2048 * 512 = 1048576 bytes\n', 'Units = cylinders of 2048 * 512 = 1048576 bytes\n', 'Units = cylinders of 2048 * 512 = 1048576 bytes\n', 'Units = cylinders of 2048 * 512 = 1048576 bytes\n']
['\n']
['Device', 'Start', 'End', 'Blocks', 'Id', 'System']
['/dev/sda1', '1', '7560', '7741439+', 'b', 'Win95', 'FAT32']
