Cron manager
kccalex
hello
i have a situation here in my vu duo with Black hole image
i want have a script checking every minute if a program its runing in my box, but the options at cron manager are only to select a specify hour to execute the comand....
so there is any way to avoid that and execute the script every minute like i said?
also how i can add another pre-defined commands on blackhole?
thx in advance
Make the script, transfer it in /var/script and give attribute 755.
The go in /etc/bhcron and add the command line in both files from there : bh.cron and root.
It works for me.
hello
thx in advance
Sure,
do what george said.
I have the same problem, but in /etc/bhcron/ does i not have any files. How does i make the to files bh.cron and root?
If you go in blue panel, cron manager you can add same command in cron and BH will create the files.
