Crond Manager doesn´t work
el_zari
BH Lover
Good morning....
Latest image for Vu+Zero, crond manager doesn´t work. I put the hour/minutes for reboot decoder, but doesn´t work. Any ideas please?
Thanks
- you made online update or new instalation ?
- you have similar setup like in past version image BH 3.0.9 B ?
Both. One new installation, and one online update. Any fix?
Same configuration before and crond worked 100%.
Thanks a lot.
Hi,
image: BlackHole-3.0.8-vuzero_usb_release_20181224_aa3715e
The crond service script (/etc/init.d/) is missing.
If you manually start the cron daemon, all crons listed in crontab will work.
Oct  9 19:24:27 vuzero cron.info crond[23951]: crond (busybox 1.23.2) started, log level 8
Oct  9 19:25:00 vuzero cron.info crond[23951]: USER root pid 23974 cmd /bin/date >> /home/root/cron.log
