Cross EPG slow as hell
Pixs
Hello,
Getting EPG data from rytec sources is slow as hell.
Downloading is fine and quick but data parsing is very slow and almost does not seem to progress at all.
I would like to download Benelux, France, Germany and Spain.
It slow even when I choose only one provider.
I am running BH 3.0.3Q on a Solo2.
I hope someone will be able to help.
Thanks.
I have no problem either with my RAM or Hard Drive space and it's still slow. The problem is even not a broadband speed. One provider takes 10 minutes to upload. It's really annoying.
Maybe alot people try download epg in one time.
Im remember in past posts on Pli forum about change manualy time download.
Hello,
Thanks.
CROSSEpg works this way: it's not, as you noticed, a download issue but a post-processing one. It has always been so and still is. It doesn't depend on the box as it is so with Duo2 as well with Solo4K.
When I used it under BH, I simply programmed it at night otherwise I couldn't control my box for about 40 minutes as it doesn't work in background like EPG-Import... (although is possible to do something by OpenWebIf).
If you want speed, you need OBH and EPGImport. But, if I'm not wrong, there is also a guide to use EPG-import under BH, somehow.
I scheduled a EPG download at 3am and hopefully everything worked fine.
The box has not crashed.
It seems to take time...
