Cross EPG wont aauto update
I am using Blackhole 1.7.0 and my cross epg wont auto update , if i restart GUI it then updates once and thats it.
Can anyone help???
I think the first thing you have to do is update img, we have now BH 205, you have 170, it is very old
Then we can check what is the problem.
Can you tell me how to do this please? As im a newbie to all of this
It all depens on what you want to save.
For normal configurazione you can use software manager, but if you want to save something particular you have to set it up.
But we are offtopic here.
Make a new post.
Hi i have same problem wiith crossepg the auto update not work i put once every week and set time after 3 minut nothing happen
