Request CrossEPG 0.8.6 stopped working with Rytec
gogglebox
Hi,
All of a sudden CrossEPG 0.8.6 doesn’t load rytec sources and can no longer find them.
I see OBH has 0.8.7, if a BH compliant version exists, is it possible to provide this update to the feeds?
Hello,
i try your solution but that does not work... I have 2 vu plus (one solo 4K and one zero) same issue...
Do you have any idea?
Just searching a bit on the Internet and in this forum itself, you would find this is a recent issue: until a few weeks ago, the rytec fonts update worked normally. But it's been a while since it doesn't any longer.
Please, report to the plugin author (usually in GitHub).
