CrossEPG issue with BH2.1.0.1 image
nims076
Hi,
I have a Vu Duo with 1 tuner in there.
I previously had BH 2.0.3 which had Crossepg 6.2 and OpenTV 28.2 would update as normal with no issues to my mounted USB.
I have upgraded to the latest BH image which has Crossepg 0.8.1 and crossepg will not download OpenTV.
I configure it the same as I did previously and when I select Download, its states downloading and then after 30sec or so, that disappears and nothing has happened. It doesnt do what it did previously and download, read, parse, etc.
Any ideas as to what is wrong please?
Would suggest you go to Menu/Setup/Crossepg/Opentvproviders. Choose one of the options and press enter on remote. A green icon will light up. Press Download (yellow button). Press Save (green button) before pressing Exit.
