crossepg setup problem
kornale
Hi,
I am trying to set crossepg on BH2.0.8.1.
I can download the epg and I see the db growing using telnet.
At the end I get ext.epg.dat but no epg.dat
I found the script crossepg_epgmove.sh which copies the ext.epg.dat to epg.dat at the proper location which is configuerd in /etc/enigma2/settings
config.misc.epgcache_filename=/usr/crossepg/data/epg.dat
I can see the epg.dat is copied properly.
I use the internal flash just for now for testing and it is not full (checked with df)
How do I get the epg loaded? I always see the default epg from the cable provider which has not all channels.
Even if I delete all egp.dat files (checked with find / -name epg.dat) I still get the default epg from the cable provider.
What am I missing to see epg from crossepg?
Thanks for your help
