crush after update to 4.3 build 36
abdou14200
OpenBh Enigma2 Crashlog
Crashdate = Sat Jul 11 14:04:06 2020
Creator = OpenBH
Version = 4.3
Build = 036
Type = release
Machine = vuuno4kse
URL = http://www.vuplus-community.net
Compiled = Jul 11 2020
Skin = MX_Sline-Grey/skin.xml
Component = Enigma2
Kernel CMDline = root=/dev/mmcblk0p4 rootfstype=ext4 rootflags=data=journal rootwait rw coherent_pool=2M vmalloc=666m bmem=641m@350m bmem=641m@2430m
Nim Sockets = NIM Socket 0:
Type: DVB-S2
Name: Vuplus DVB-S NIM(45208 FBC)
Frontend_Device: 0
NIM Socket 1:
Type: DVB-S2
Frontend_Device: 1
NIM Socket 2:
Type: DVB-S2
Frontend_Device: 2
NIM Socket 3:
Type: DVB-S2
Frontend_Device: 3
NIM Socket 4:
Type: DVB-S2
Frontend_Device: 4
NIM Socket 5:
Type: DVB-S2
Frontend_Device: 5
NIM Socket 6:
Type: DVB-S2
Frontend_Device: 6
NIM Socket 7:
Type: DVB-S2
Frontend_Device: 7
hi] avahi_timeout_update
< 440.6023> 13:56:21.9715 [eDVBFrontend0] sleep 200ms
< 440.6023> 13:56:21.9716 [Avahi] timeout elapsed
< 440.6023> 13:56:21.9716 [Avahi] REMOVE service 'vuuno4kse' of type '_e2stream._tcp' in domain 'local'
< 440.6023> 13:56:21.9716 REMOVE Peer vuuno4kse
< 440.6023> 13:56:21.9716 [Avahi] avahi_timeout_update
< 440.6024> 13:56:21.9716 [Avahi] timeout elapsed
< 440.6024> 13:56:21.9717 [Avahi] avahi_timeout_update
< 440.6024> 13:56:21.9717 [Avahi] timeout elapsed
< 440.6025> 13:56:21.9717 [Avahi] Resolving service 'vuuno4kse' of type '_e2stream._tcp'
< 440.6026> 13:56:21.9719 [Avahi] avahi_timeout_new
< 440.6038> 13:56:21.9730 [Avahi] avahi_timeout_free
< 440.6038> 13:56:21.9731 [Avahi] avahi_timeout_update
< 440.6039> 13:56:21.9731 [Avahi] timeout elapsed
< 440.6039> 13:56:21.9732 [Avahi] Resolving service 'vuuno4kse' of type '_e2stream._tcp'
< 440.6041> 13:56:21.9733 [Avahi] avahi_timeout_new
< 440.6055> 13:56:21.9748 [Avahi] avahi_timeout_free
< 440.6056> 13:56:21.9749 [Avahi] avahi_timeout_update
< 440.6057> 13:56:21.9750 [Avahi] timeout elapsed
< 440.6059> 13:56:21.9752 [Avahi] avahi_timeout_new
< 440.6066> 13:56:21.9758 [Avahi] avahi_timeout_free
< 440.6066> 13:56:21.9759 [Avahi] avahi_timeout_update
< 440.6067> 13:56:21.9760 [Avahi] timeout elapsed
< 440.6068> 13:56:21.9760 [Avahi] avahi_timeout_new
< 440.6073> 13:56:21.9766 [Avahi] avahi_timeout_free
< 440.6074> 13:56:21.9766 [Avahi] avahi_timeout_update
< 440.6074> 13:56:21.9767 [Avahi] timeout elapsed
< 440.6075> 13:56:21.9768 [Avahi] avahi_timeout_new
< 440.6083> 13:56:21.9776 [Avahi] avahi_timeout_free
< 440.6085> 13:56:21.9778 [Avahi] avahi_timeout_update
< 440.6086> 13:56:21.9779 [Avahi] timeout elapsed
< 440.6087> 13:56:21.9780 [Avahi] avahi_timeout_new
< 440.6095> 13:56:21.9787 [Avahi] avahi_timeout_free
< 440.6095> 13:56:21.9788 [Avahi] avahi_timeout_update
< 440.8023> 13:56:22.1716 [eDVBFrontend0] invalidate current switch params
< 440.8460> 13:56:22.2153 [eDVBFrontend0] sendDiseqc: e00000(DiSEqC reset)
< 440.8461> 13:56:22.2154 [eDVBFrontend0] sleep 50ms
< 440.9398> 13:56:22.3090 [eDVBFrontend0] sendDiseqc: e00003(DiSEqC peripherial power on)
< 440.9410> 13:56:22.3103 [eDVBFrontend0] sleep 150ms
< 441.1481> 13:56:22.5174 [eDVBFrontend0] sendDiseqc: e01038f6(?)
< 441.1482> 13:56:22.5174 [eDVBFrontend0] sleep 100ms
< 441.2482> 13:56:22.6175 [eDVBFrontend0] set sequence pos 3
< 441.2483> 13:56:22.6175 [eDVBFrontend0] set sequence pos 3
< 441.2483> 13:56:22.6176 [eDVBFrontend0] update current switch params
< 441.2483> 13:56:22.6176 [eDVBFrontend0] startTuneTimeout 5000
< 441.2483> 13:56:22.6176 [eDVBFrontend0] setFrontend 1
< 441.2484> 13:56:22.6176 [eDVBFrontend0] setting frontend
< 441.2607> 13:56:22.6300 [eDVBFrontend0] fe event: status 0, inversion off, m_tuning 1
< 441.2608> 13:56:22.6301 [eDVBFrontend0] sleep 500ms
< 441.3157> 13:56:22.6850 [eDVBFrontend0] fe event: status 7, inversion off, m_tuning 2
< 441.3997> 13:56:22.7690 [eDVBFrontend0] fe event: status 1f, inversion off, m_tuning 3
< 441.3998> 13:56:22.7691 [eDVBChannel] OURSTATE: ok
< 441.3998> 13:56:22.7691 [eDVBLocalTimerHandler] channel 0x203eb58 running
< 441.3999> 13:56:22.7691 [eDVBChannel] getDemux cap=00
< 441.3999> 13:56:22.7691 [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 441.4000> 13:56:22.7693 [eDVBSectionReader] DMX_SET_FILTER pid=20
< 441.4004> 13:56:22.7697 [eEPGCache] channel 0x203eb58 running
< 441.4004> 13:56:22.7697 [eDVBChannel] getDemux cap=00
< 441.4005> 13:56:22.7697 [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 441.4005> 13:56:22.7698 [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 441.4006> 13:56:22.7698 [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 441.4006> 13:56:22.7699 [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 441.4007> 13:56:22.7699 [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 441.4007> 13:56:22.7700 [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 441.4008> 13:56:22.7700 [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 441.4008> 13:56:22.7701 [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 441.4009> 13:56:22.7701 [eDVBResourceManager] stop release channel timer
< 441.4009> 13:56:22.7701 [eDVBChannel] getDemux cap=01
< 441.4009> 13:56:22.7702 [eDVBResourceManager] allocate demux cap=01
< 441.4009> 13:56:22.7702 [eDVBResourceManager] allocating shared demux adapter=0, demux=0, source=0
< 441.4009> 13:56:22.7702 [eDVBServicePMTHandler] ok ... now we start!!
< 441.4009> 13:56:22.7702 [eDVBServicePlay] eventNewProgramInfo timeshift_enabled=0 timeshift_active=0
< 441.4010> 13:56:22.7702 [eDVBServicePlay] have 1 video stream(s) (02ff), and 1 audio stream(s) (0304), and the pcr pid is 02ff, and the text pid is ffffffff
< 441.4010> 13:56:22.7703 [eDVBChannel] getDemux cap=01
< 441.4019> 13:56:22.7711 [eEPGCache] next update in 2 sec
< 441.4297> 13:56:22.7990 [eTSMPEGDecoder] decoder state: play, vpid=02ff, apid=0304
< 441.4298> 13:56:22.7990 [eDVBPCR0] DMX_SET_PES_FILTER pid=0x02ff ok
< 441.4298> 13:56:22.7991 [eDVBPCR0] DEMUX_START ok
< 441.4556> 13:56:22.8249 [eDVBAudio0] DMX_SET_PES_FILTER pid=0x0304 ok
< 441.4557> 13:56:22.8249 [eDVBAudio0] DEMUX_START ok
< 441.4557> 13:56:22.8250 [eDVBAudio0] AUDIO_SET_BYPASS bypass=0 ok
< 441.4643> 13:56:22.8336 [eDVBAudio0] AUDIO_PAUSE ok
< 441.4682> 13:56:22.8375 [eDVBAudio0] AUDIO_PLAY ok
< 441.4745> 13:56:22.8438 [eDVBVideo] Video Device: /dev/dvb/adapter0/video0
< 441.4746> 13:56:22.8438 [eDVBVideo] demux device: /dev/dvb/adapter0/demux0
< 441.4900> 13:56:22.8593 [eDVBVideo0] VIDEO_SET_STREAMTYPE 1 - ok
< 441.4942> 13:56:22.8635 [eDVBVideo0] DMX_SET_PES_FILTER pid=0x02ff ok
< 441.4942> 13:56:22.8635 [eDVBVideo0] DEMUX_START ok
< 441.4943> 13:56:22.8635 [eDVBVideo0] VIDEO_FREEZE ok
< 441.4979> 13:56:22.8672 [eDVBVideo0] VIDEO_PLAY ok
< 441.5068> 13:56:22.8760 [eDVBVideo0] VIDEO_SLOWMOTION 0 ok
< 441.5110> 13:56:22.8802 [eDVBVideo0] VIDEO_FAST_FORWARD 0 ok
< 441.5155> 13:56:22.8847 [eDVBVideo0] VIDEO_CONTINUE ok
< 441.5193> 13:56:22.8886 [eDVBAudio0] AUDIO_CONTINUE ok
< 441.5273> 13:56:22.8965 [eDVBAudio0] AUDIO_CHANNEL_SELECT 0 ok
< 441.5316> 13:56:22.9008 [eDVBTeletextParser] Starting!
< 441.5316> 13:56:22.9009 [eDVBTeletextParser] disable teletext subtitles page ffffffffffffffff (und)
< 441.5316> 13:56:22.9009 [eDVBPESReader] Created. Opening demux
< 441.5316> 13:56:22.9009 [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 441.5317> 13:56:22.9009 [eDVBTeletextParser] created teletext subtitle PES reader!
< 441.5318> 13:56:22.9010 [eDVBPESReader] Created. Opening demux
< 441.5318> 13:56:22.9010 [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 441.5318> 13:56:22.9011 [eDVBTeletextParser] starting PES reader on pid=ffffffff
< 441.7209> 13:56:23.0902 [eDVBCAService] new service 1:0:19:74:9:85:C00000:0:0:0:
< 441.7209> 13:56:23.0902 [eDVBCAService] add demux 0 to slot 0 service 1:0:19:74:9:85:C00000:0:0:0:
< 441.7210> 13:56:23.0902 [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 441.7210> 13:56:23.0903 [eDVBSectionReader] DMX_SET_FILTER pid=0
< 441.7423> 13:56:23.1115 [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 441.7423> 13:56:23.1116 [eDVBSectionReader] DMX_SET_FILTER pid=18
< 441.7457> 13:56:23.1150 [Notifications] RemovePopup, id = ZapError
< 441.7458> 13:56:23.1151 [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 441.7459> 13:56:23.1152 [eDVBSectionReader] DMX_SET_FILTER pid=0
< 441.7518> 13:56:23.1211 [eDVBVideo0] VIDEO_GET_EVENT SIZE_CHANGED 1280x720 aspect 3
< 441.7609> 13:56:23.1302 [eDVBFrontend0] set dynamic current limiting
< 441.8150> 13:56:23.1843 [eDVBServicePMTHandler] PATready
< 441.8151> 13:56:23.1844 [eDVBServicePMTHandler] use pmtpid 0062 for service_id 0074
< 441.8151> 13:56:23.1844 [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 441.8152> 13:56:23.1845 [eDVBSectionReader] DMX_SET_FILTER pid=98
< 441.8155> 13:56:23.1848 [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 441.8156> 13:56:23.1848 [eDVBSectionReader] DMX_SET_FILTER pid=0
< 441.8166> 13:56:23.1859 [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 441.8166> 13:56:23.1859 [eDVBSectionReader] DMX_SET_FILTER pid=101
< 441.8169> 13:56:23.1862 [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 441.8169> 13:56:23.1862 [eDVBSectionReader] DMX_SET_FILTER pid=17
< 441.8898> 13:56:23.2591 [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 441.8899> 13:56:23.2591 [eDVBSectionReader] DMX_SET_FILTER pid=98
< 441.8994> 13:56:23.2687 [eDVBServicePlay] eventNewProgramInfo timeshift_enabled=0 timeshift_active=0
< 441.8998> 13:56:23.2691 [Config] getResolvedKey config.autolanguage.audio_autoselect4 empty variable.
< 441.9000> 13:56:23.2693 [Config] getResolvedKey config.autolanguage.subtitle_autoselect1 empty variable.
< 441.9001> 13:56:23.2694 [Config] getResolvedKey config.autolanguage.subtitle_autoselect2 empty variable.
< 441.9002> 13:56:23.2695 [Config] getResolvedKey config.autolanguage.subtitle_autoselect3 empty variable.
< 441.9003> 13:56:23.2696 [Config] getResolvedKey config.autolanguage.subtitle_autoselect4 empty variable.
< 441.9005> 13:56:23.2698 [eDVBServicePlay] have 1 video stream(s) (02ff), and 2 audio stream(s) (0303, 0304), and the pcr pid is 02ff, and the text pid is ffffffff
< 441.9007> 13:56:23.2699 [eTSMPEGDecoder] decoder state: play, vpid=02ff, apid=0304
< 441.9007> 13:56:23.2699 [eDVBVideo0] VIDEO_SLOWMOTION 0 ok
< 441.9052> 13:56:23.2744 [eDVBVideo0] VIDEO_FAST_FORWARD 0 ok
< 441.9099> 13:56:23.2792 [eDVBVideo0] VIDEO_CONTINUE ok
< 441.9138> 13:56:23.2831 [eDVBAudio0] AUDIO_CONTINUE ok
< 441.9227> 13:56:23.2920 [Config] getResolvedKey config.autolanguage.audio_autoselect4 empty variable.
< 441.9228> 13:56:23.2921 [Config] getResolvedKey config.autolanguage.subtitle_autoselect1 empty variable.
< 441.9229> 13:56:23.2922 [Config] getResolvedKey config.autolanguage.subtitle_autoselect2 empty variable.
< 441.9230> 13:56:23.2923 [Config] getResolvedKey config.autolanguage.subtitle_autoselect3 empty variable.
< 441.9231> 13:56:23.2924 [Config] getResolvedKey config.autolanguage.subtitle_autoselect4 empty variable.
< 442.1154> 13:56:23.4847 [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 442.1155> 13:56:23.4848 [eDVBSectionReader] DMX_SET_FILTER pid=98
< 442.1169> 13:56:23.4862 [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 442.1170> 13:56:23.4863 [eDVBSectionReader] DMX_SET_FILTER pid=100
< 442.2376> 13:56:23.6069 [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 442.2377> 13:56:23.6069 [eDVBSectionReader] DMX_SET_FILTER pid=103
< 442.2589> 13:56:23.6281 [VideoHardware] setting aspect: 16:9
< 442.2592> 13:56:23.6284 [VideoHardware] setting wss: auto
< 442.2593> 13:56:23.6286 [VideoHardware] setting policy: bestfit
< 442.2596> 13:56:23.6288 [VideoHardware] setting policy2: scale
< 442.3360> 13:56:23.7053 [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 442.3361> 13:56:23.7054 [eDVBSectionReader] DMX_SET_FILTER pid=102
< 442.4428> 13:56:23.8120 [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 442.4429> 13:56:23.8121 [eDVBSectionReader] DMX_SET_FILTER pid=99
< 442.4777> 13:56:23.8470 [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 442.4778> 13:56:23.8471 [eDVBSectionReader] DMX_SET_FILTER pid=113
< 442.9485> 13:56:24.3177 [eDVBVideo0] VIDEO_GET_EVENT SIZE_CHANGED 1920x1080 aspect 3
< 442.9562> 13:56:24.3255 [eDVBVideo0] VIDEO_GET_EVENT PROGRESSIVE_CHANGED 0
< 443.0091> 13:56:24.3783 [eDVBServicePMTHandler] sdt update done!
< 443.4061> 13:56:24.7753 [eEPGCache] start caching events(1594472184)
< 443.4061> 13:56:24.7754 [eDVBSectionReader] DMX_SET_FILTER pid=3842
< 443.4065> 13:56:24.7758 [eDVBSectionReader] DMX_SET_FILTER pid=3003
< 443.4069> 13:56:24.7762 [eDVBSectionReader] DMX_SET_FILTER pid=18
< 443.4076> 13:56:24.7768 [eDVBSectionReader] DMX_SET_FILTER pid=18
< 443.4084> 13:56:24.7776 [eDVBSectionReader] DMX_SET_FILTER pid=18
< 443.4094> 13:56:24.7786 [eDVBSectionReader] DMX_SET_FILTER pid=700
< 443.4096> 13:56:24.7789 [eDVBSectionReader] DMX_SET_FILTER pid=700
< 443.4101> 13:56:24.7794 [eDVBSectionReader] DMX_SET_FILTER pid=5000
< 443.4104> 13:56:24.7797 [eDVBSectionReader] DMX_SET_FILTER pid=5000
< 443.4109> 13:56:24.7802 [huffman] read.. '/usr/share/enigma2/otv_00c00000_0085_0009.dict'
< 443.4110> 13:56:24.7803 [eEPGCache] abort non avail OpenTV EIT reading
< 443.4110> 13:56:24.7803 [eDVBSectionReader] DMX_SET_FILTER pid=57
< 443.4578> 13:56:24.8271 [VideoHardware] setting aspect: 16:9
< 443.4581> 13:56:24.8274 [VideoHardware] setting wss: auto
< 443.4583> 13:56:24.8276 [VideoHardware] setting policy: bestfit
< 443.4586> 13:56:24.8278 [VideoHardware] setting policy2: scale
< 443.6335> 13:56:25.0028 [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 443.6336> 13:56:25.0029 [eDVBSectionReader] DMX_SET_FILTER pid=18
< 444.1174> 13:56:25.4867 [eDVBLocalTimerHandler] dont have correction.. set Transponder Diff
< 444.1174> 13:56:25.4867 [eDVBLocalTimerHandler] set RTC Time
< 444.2270> 13:56:25.5963 [eDVBLocalTimerHandler] update RTC
< 444.2271> 13:56:25.5963 [eDVBLocalTimerHandler] time update to 13:56:23
< 444.2271> 13:56:25.5963 [eDVBLocalTimerHandler] m_time_difference is -2
< 444.2271> 13:56:25.5964 [eDVBLocalTimerHandler] slewing Linux Time by -02 seconds
< 444.2286> 13:56:25.5978 [eDVBChannel] getDemux cap=00
< 450.4113> 13:56:31.7805 [eEPGCache] abort non avail schedule other reading
< 450.4123> 13:56:31.7816 [eEPGCache] abort non avail virgin nownext reading
< 450.4127> 13:56:31.7820 [eEPGCache] abort non avail virgin schedule reading
< 450.4129> 13:56:31.7821 [eEPGCache] abort non avail netmed schedule reading
< 450.4135> 13:56:31.7827 [eEPGCache] abort non avail netmed schedule other reading
< 450.4136> 13:56:31.7829 [eEPGCache] abort non avail FreeSat schedule_other reading
< 450.4138> 13:56:31.7831 [eEPGCache] abort non avail viasat reading
< 450.4174> 13:56:31.7867 [eEPGCache] nownext finished(1594472191)
< 452.5632> 13:56:33.9325 [eEPGCache] schedule finished(1594472193)
< 452.5638> 13:56:33.9330 [eEPGCache] stop caching events(1594472193)
< 452.5638> 13:56:33.9331 [eEPGCache] next update in 60 min
< 616.9498> 13:59:18.3191 [Timezones] AutoTimer poll is running.
< 616.9499> 13:59:18.3192 [Timezones] AutoTimer is parsing the EPG.
< 616.9527> 13:59:18.3220 [Task] job Components.Task.Job name=AutoTimer #tasks=0 completed with [] in None
< 619.3001> 13:59:20.6694 [AutoTimer] current auto poll 2020-07-11 13:59:20
< 619.3002> 13:59:20.6695 [AutoTimer] Auto Poll Started
< 619.3005> 13:59:20.6698 [AutoTimer] No changes in configuration, won't parse
< 619.3018> 13:59:20.6711 [Task] job Components.Task.Job name=AutoTimer #tasks=0 completed with [] in None
< 619.3022> 13:59:20.6714 [AutoTimer] next auto poll at 2020-07-11 17:59:20
< 796.6428> 14:02:18.0121 [Harddisk] Command: 'hdparm -y /dev/sda'.
< 905.2002> 14:04:06.5695 [eInputDeviceInit] 1 8b (139) 1
< 905.2010> 14:04:06.5703 [InfoBarGenerics] KEY: 139 MENU
< 905.2014> 14:04:06.5706 Traceback (most recent call last):
< 905.2014> 14:04:06.5706 File "/usr/lib/enigma2/python/Screens/InfoBarGenerics.py", line 237, in actionA
< 905.2016> 14:04:06.5708 File "/usr/lib/enigma2/python/Screens/InfoBarGenerics.py", line 251, in closeSIB
< 905.2017> 14:04:06.5709 AttributeError: 'InfoBar' object has no attribute 'sibIgnoreKeys'
< 905.2018> 14:04:06.5710 [ePyObject] (CallObject(<bound method InfoBar.actionA of <class 'Screens.InfoBar.InfoBar'>>,(139, 0)) failed)
dmesg
<4>[ 432.931327] [VID]: VIDEO_SET_STREAMTYPE 0
<4>[ 432.936134] [VID]: VIDEO_SELECT_SOURCE 1 1
<4>[ 432.941110] [VID]: VIDEO_PLAY 1 2 0
<4>[ 432.950442] [VID]: VIDEO_CONTINUE 1 1
<4>[ 432.954527] [VID]: VIDEO_CLEAR_BUFFER 1 1 0
<4>[ 433.230337] [VID]: VIDEO_STOP 0 1
<4>[ 433.234826] [VID]: VIDEO_SELECT_SOURCE 0 0
<4>[ 439.379126] [AUD]: AUDIO_SET_MUTE 0
<4>[ 439.383071] [AUD]: AUDIO_SET_MIXER -745283952
<4>[ 439.387560] [AUD]: AUDIO_SET_MIXER : amixl 0, amixr 0
<4>[ 439.392647] [AUD]: AUDIO_SET_MIXER : next left volume -3284, right volume -3284
<4>[ 439.399996] [AUD]: AUDIO_SET_MIXER : next left volume -70, right volume -70
<4>[ 440.097391] [AUD]: AUDIO_SET_MIXER -745283952
<4>[ 440.101871] [AUD]: AUDIO_SET_MIXER : amixl 45, amixr 45
<4>[ 440.107123] [AUD]: AUDIO_SET_MIXER : next left volume -70, right volume -70
<4>[ 440.114125] [AUD]: AUDIO_SET_MIXER : next left volume -3284, right volume -3284
<4>[ 441.316531] FE tune
<4>[ 441.498150] [AUD]: AUDIO_SELECT_SOURCE 0
<4>[ 441.502216] [AUD]: AUDIO_SELECT_SOURCE clean up
<4>[ 441.523958] [AUD]: AUDIO_SET_BYPASS_MODE 0
<4>[ 441.528224] [AUD]: AC3 downmix 0 state : 0
<4>[ 441.532555] [AUD]: AUDIO_PAUSE 0
<4>[ 441.536484] [AUD]: AUDIO_PLAY 0 decoder start : 0
<4>[ 441.542807] [VID]: VIDEO_SELECT_SOURCE 0 0
<4>[ 441.547043] [VID]: VIDEO_GET_SIZE src w: 1280 h:720 display w:1280 h:720
<4>[ 441.553777] [VID]: VIDEO_GET_SIZE aspect: 1 3
<4>[ 441.558293] [VID]: VIDEO_SET_STREAMTYPE 1
<4>[ 441.562518] [VID]: VIDEO_FREEZE 0 0
<4>[ 441.566182] [VID]: VIDEO_PLAY 0 5 2
<4>[ 441.575034] [VID]: VIDEO_SLOWMOTION 0 1
<4>[ 441.579226] [VID]: VIDEO_FAST_FORWARD 0 1 0
<4>[ 441.583716] [VID]: VIDEO_CONTINUE 0 1
<4>[ 441.587588] [AUD]: AUDIO_CONTINUE 0 1 aph=0xd0a57980
<4>[ 441.592567] [AUD]: Mute : 0
<4>[ 441.595537] [AUD]: AUDIO_CHANNEL_SELECT 0
<4>[ 441.969123] [VID]: VIDEO_SLOWMOTION 0 1
<4>[ 441.973620] [VID]: VIDEO_FAST_FORWARD 0 1 0
<4>[ 441.978368] [VID]: VIDEO_CONTINUE 0 1
<4>[ 441.982246] [AUD]: AUDIO_CONTINUE 0 1 aph=0xd0a57980
<4>[ 441.987236] [AUD]: Mute : 0
