denon54
Hi all,
I already post such post a couple of time ago, but still no luck.
I upgrade to BH 2.0.9 yesterday on my vu+duo2 and still the same issue.
At the very beginnning when i received my vu+duo2 , i installed a BH 2.0.7.1 and
with that specific firmware i could use without problem the dlna function to watch
a channel on another device ( Panasonic-TV ) through dlna.
Since then no luck, i of course upgraded each time a new firmware was available but doesn't
work anymore.
Phenomenon is , when i start the dlna function on my tv set , i can see the vu+duo2,
i then select it and can see folder and even all channel Inside each favourite.
When i select a channel i got as message ==> please wait.
It is not that the tvset is not compatible with .m3u files because i could use before with previous
firmware!
Iaslso made a test with mediatomb , but exactly the same issue.
i have my both tuner connected , dlna server is also enable and tuner built.
If anyone has an idea , because it was really one of the major point why
i bought that receiver, so i am a bit confused.
thank you in advance for your help.
joel from Brussels
work anymore.
firmware!
joel from Brussels
