D-LINK DWA-111 WIFI USB PROBLEM
afram
Hello, I have a Wi-Fi USB D-LINK DWA -111 , AND I WANT TO INSTALL IT IN MY VU+ SOLO But it does not recognize the device please help me ???????
I move the thread into correct section.
Could you please post firmware and hardware revision of your device? It's very important!
Update: your device should use the (old) RT73 driver already included into image.
I don't have (yet) a device compatible with this driver but I can catch it into a few days and make some tests.
thank you angelofsky
the firmware is blackhole 1.7.7 and the hardware is new kernel , sorry i'm a new vu+ user thanx .
There is a misunderstanding.
I refer to hardware revision and firmware revision of Wireless USB stick DWA-111.
Usually there is a stick attached on device or on the box with these infos.
