D-link DWA-160 WIFI USB [unknown]
Hello ...
I just want to know, does the D-Link DWA-160 work with VU+Duo or Solo ?
thanks alot
I need some infos about your device like the data reported on the back sticker of your device.
There are some versions of DWA-160 shipped around the world :( and I cannot be sure to give you the correct answer and try to support it ....
