dcc error
Mick12334
Moderator
Hi anana,
welcome to the forum.
Have you used the search option, to see if your receiver is recognized on your network, and that you have the correct IP Address?
Have you also tried the VU+ Control Centre?
If you've already tried these options can you please provide more detailed information.
gasth404
Interesting ;) is there new (working) version VU+ Control Centre. Last version stop working for me same time ago. Now can i connect with my Vu+Ultimo 4k only with webinterface or with file changing programm (filezilla ...)
Peitacas
Helllo all,
@anana were you able to fix the issue?
@all
I got the same today with my Solo4k. With my Solo SE all good. Tried with DCC, with VuCC and Echannelizer
my troubleshooting so far:
DHCP Enabled
Lan Cable - Error 10057
WiFI - Error 10057
DHCP Disabled
WiFI - Error 10057
Going to Black Hole Setting - FTP Panel - Status "Stopped". Red button pushed to enable it but it doesn´t change, always "Stopped"
As I have multiboot, tried on OpenPLi 6.2 and it works perfectly. So it is something on Blackhole configuration. Any ideas?
Thanks in advance.
Peitacas
AlexWilMac
Moderator
No, it's not a configuration issue. Sometimes it has happened to me too that the FTP service stopped working. I manage to fix it without reinstalling the image and flashing the only kernel, but it's quit experimental ;)
You need to reflash the image, otherwise, saving your settings. There is not only DCC in this world, anyway. Under win you can also try dreamboxedit or, even better (if it's still working), the Open Webinterface and its bouquet editor.
Peitacas
Thanks Alexwilmac! and how do I do to install only the Kernel? for now the Open WebIf allowed me to backup my channel list, thanks for the tip ;) what about the other config files?
AlexWilMac
Moderator
The "only kernel" is a procedure I haven't repeated for a long, long, time, especially with BH.
So, I don't want responsibility for that!!! ;) Anyway, if it got wrong, you'll always have the chance of a complete reflash.
To flash only the kernel you have to prepare a usb flashdrive the same way as for a complete flash but then you must remove the file containing the root (root_cfe_auto.bin or rootfs.tar.bz2 or similar names).
This way you won't loose neither your settings (channels) nor the plugins.
Instead, if you want to reflash from scratch, I don't recommend (especially with BH) the so called "personal backup" which should backup also the plugins. It has never worked 100% for me.
I much prefer to reinstall the plugins: few minutes of your time but everything is then perfectly working.
Peitacas
Thanks, and don´t worry. If I do something wrong I will reflash from scratch ;)
I will let you know if it worked.
Thanks!
Mick12334
Moderator
Error 10057 can mean that you have changed the password, or the wrong IP Address, the default password, for the VU+, is left blank, or dreambox does work.
The Solo 4K and the Solo SE, use different chipsets, but that shouldn't cause any problems.
You could try disabling DHCP, saving it, then turning off your receiver. Re-boot your router, by turning it off, then on again, then switch on your VU+ Solo 4K, go back into the menu and heck your receivers IP Address.
You could also use the DCC, Dreambox Control Centre, to locate all equipment connected to your network, along with their assigned IP Addresses.
Moderator
It´s not possible to reflsah only the kernel, if the image is running in OpenMultiboot and not in the Flash.
AlexWilMac
Moderator
I assumed, from post #5, that he tried in multiboot another image, as he's got BH installed in flash.
Can you confirm this is your configuration, Peitacas? Otherwise, what Nunigaia says is true!
Peitacas
Hello both,
BH is on the flash.
Thanks
Peitacas
Helllo Nunigaia,
it is the 3.0.5.L
keep in mind it was working perfectly 2 weeks ago when I have updated the channel list for the last time.
Regards
Moderator
Helllo Nunigaia,
it is the 3.0.5.L
Regards
Just reflash the box with "ONLY" the following 2 files, but don´t forget to maintain the directory structure intact at the root of the USB device ( Pen drive ) as:
reboot.update
kernel_auto.bin
1) If you have on your PC the BlackHole Image that you have flashed your STB, use it ... otherwise, download from our server.
2) Unzip to a folder to your PC ... and copy the vuplus folder to the root of your Pen drive previously initialized as Fat32 FS.
3) Erase the files not needed.
Peitacas
How did you update your channel list?
E-Channelizer
reboot.update
kernel_auto.bin
done, but still the error 10057
