Duo2 Dead duo2
DamacFunkin
I've had my duo2 6 weeks now, a few weeks ago it seemed dead, after having it unplugged for a long time it came back to life, but gradually it hd started to crash, now it has crashed and won't boot past the splash screen, strangely it will let me re flash it via USB, I've tried every available image but on reboot it stops at the splash screen, I have managed to create a terminal output which seems to indicate a memory fault.... What do the experts think?
BCM74250012
M0
M1
01CZL2=1
LLMB=0000C000
BP=02000000
L2Cfg=1E7AD627
L2Buf=77707711
BrCfg=F01C200E
BrMod=02800801
BrZp0=44000000
BrZp1=00002000
CFE ver 2.333.20130710, Endian Mode: Little
Build Date: Mon Jul 15 19:29:18 2013 Vuplus Team
Copyright (C) Broadcom Corporation.
ERROR: MEMC1 reshmoo status = 80000008
CPU speed: 1305MHz
DDR Frequency: 800 MHz
DDR Mode: DDR3
Total memory(MEMC 0): 1024MB
MEMC 0 DDR Width: 32
Total memory(MEMC 1): 1024MB
MEMC 1 DDR Width: 32
Boot Device: NAND
Total flash: 512MB
RTS VERSION: 20120919184252_7425_single_encode
ETH0_PHY: RGMII
ETH0_MDIO_MODE: 1
ETH0_SPEED: 1000
ETH0_PHYADDR: probe
SCB CLOCK = 277MHz
Initializing USB.
USB: Locating Class 09 Vendor 0000 Product 0000: USB Root Hub
CFE initialized.
USB: New device connected to bus 3 hub 1 port 1
USB: Resetting device on bus 3 hub 1 port 1
USB: Locating Class FF Vendor 148F Product 5372: Driver not found.
waiting for usb...done
checking usb
No Priority Usb
checking front key
Checking usbdisk0:/vuplus/duo2/ignore.update......NO
Checking usbdisk0:/vuplus/duo2/force.update......NO
Checking usbdisk0:/vuplus/duo2/cfe_cfe_auto.bin......NO
Checking usbdisk0:/vuplus/duo2/root_cfe_auto.bin......NO
Checking usbdisk0:/vuplus/duo2/splash_cfe_auto.bin......NO
Checking usbdisk0:/vuplus/duo2/kernel_cfe_auto.bin......NO
Starting splash screen.
Found splash image - Width = 720 Height = 480
Non Interlaced Replace list 043f8100 0c800000Interlaced Replace list 043f86a0 0c8005a0
Loader:elf Filesys:raw Dev:flash0.kernel File: Options:ubiroot rootflags=sync bmem=192M@64M bmem=458M@512M memc1=590M
Loading: 0x80001000/7083520 0x806c2600/160720 Entry address is 0x8053af10
Starting program at 0x8053af10
Linux version 3.3.8-2.0 (build@buildserver) (gcc version 4.8.2 (GCC) ) #1 SMP Sun Apr 13 18:06:08 CEST 2014
Fetching vars from bootloader... found 17 vars.
Options: moca=0 sata=1 pcie=0 usb=1
Using 1024 MB + 1024 MB RAM (from CFE)
bootconsole [early0] enabled
CPU revision is: 00025a11 (Brcm4380)
FPU revision is: 00130001
Determined physical RAM map:
memory: 10000000 @ 00000000 (usable)
memory: 30000000 @ 20000000 (usable)
memory: 24e00000 @ 90000000 (usable)
bmem: adding 192 MB RESERVED region at 64 MB (0x0c000000@0x04000000)
bmem: adding 458 MB RESERVED region at 512 MB (0x1ca00000@0x20000000)
Zone PFN ranges:
Normal 0x00000000 -> 0x00050000
HighMem 0x00050000 -> 0x000b4e00
Movable zone start PFN for each node
Early memory PFN ranges
0: 0x00000000 -> 0x00010000
0: 0x00020000 -> 0x00050000
0: 0x00090000 -> 0x000b4e00
PERCPU: Embedded 7 pages/cpu @81e12000 s5632 r8192 d14848 u32768
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 407396
Kernel command line: ubiroot rootflags=sync bmem=192M@64M bmem=458M@512M memc1=590M ubi.mtd=rootfs rootfstype=ubifs root=ubi0:rootfs libata.force=1:1.5Gbps
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Primary instruction cache 32kB, physically tagged, 4-way, linesize 64 bytes.
Primary data cache 32kB, 4-way, linesize 32 bytes.
MIPS secondary cache 256kB, 8-way, linesize 128 bytes.
Memory: 964796k/1048576k available (5446k kernel code, 687940k reserved, 1277k data, 192k init, 604160k highmem)
Hierarchical RCU implementation.
NR_IRQS:160
Measuring MIPS counter frequency...
Detected MIPS clock frequency: 1305 MHz (163.136 MHz counter)
Console: colour dummy device 80x25
Calibrating delay loop... 869.37 BogoMIPS (lpj=434688)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
SMP: Booting CPU1...
SMP: CPU1 is running
Brought up 2 CPUs
devtmpfs: initialized
bmem: adding extra 434 MB RESERVED region at 2894 MB (0x1b200000@0xb4e00000)
NET: Registered protocol family 16
USB0: power enable is active high; overcurrent is active low
USB1: power enable is active high; overcurrent is active low
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Advanced Linux Sound Architecture Driver Version 1.0.24.
cfg80211: Calling CRDA to update world regulatory domain
Switching to clocksource wktmr
NET: Registered protocol family 2
IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
TCP reno registered
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
highmem bounce pool size: 64 pages
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
NTFS driver 2.1.30 [Flags: R/W].
msgmni has been set to 704
io scheduler noop registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
console [ttyS0] enabled, bootconsole disabled 62) is a 16550A
serial8250.0: ttyS1 at MMIO 0x10406b40 (irq = 63) is a 16550A
serial8250.0: ttyS2 at MMIO 0x10406b80 (irq = 64) is a 16550A
loop: module loaded
ahci: SSS flag set, parallel bus scan disabled
ahci strict-ahci.0: AHCI 0001.0300 32 slots 2 ports 6 Gbps 0x3 impl platform mode
ahci strict-ahci.0: flags: ncq sntf stag clo slum part
scsi0 : ahci_platform
scsi1 : ahci_platform
ata1: FORCE: PHY spd limit set to 1.5Gbps
ata1: SATA max UDMA/133 mmio [mem 0x10181000-0x10190fff] port 0x100 irq 42
ata2: SATA max UDMA/133 mmio [mem 0x10181000-0x10190fff] port 0x180 irq 42
brcmstb_nand: NAND controller driver is loaded
Found PHY at Address 3
Config GPHY through MDIO
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ata1: SATA link down (SStatus 0 SControl 310)
ehci-brcm ehci-brcm.0: Broadcom STB EHCI
ehci-brcm ehci-brcm.0: new USB bus registered, assigned bus number 1
ehci-brcm ehci-brcm.0: irq 66, io mem 0x10480300
ehci-brcm ehci-brcm.0: USB 0.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
ehci-brcm ehci-brcm.1: Broadcom STB EHCI
ehci-brcm ehci-brcm.1: new USB bus registered, assigned bus number 2
ehci-brcm ehci-brcm.1: irq 67, io mem 0x10480500
ehci-brcm ehci-brcm.1: USB 0.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
ehci-brcm ehci-brcm.2: Broadcom STB EHCI
ehci-brcm ehci-brcm.2: new USB bus registered, assigned bus number 3
ehci-brcm ehci-brcm.2: irq 71, io mem 0x10490300
ehci-brcm ehci-brcm.2: USB 0.0 started, EHCI 1.00
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 1 port detected
ehci-brcm ehci-brcm.3: Broadcom STB EHCI
ehci-brcm ehci-brcm.3: new USB bus registered, assigned bus number 4
ehci-brcm ehci-brcm.3: irq 72, io mem 0x10490500
ehci-brcm ehci-brcm.3: USB 0.0 started, EHCI 1.00
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 1 port detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci-brcm ohci-brcm.0: Broadcom STB OHCI
ohci-brcm ohci-brcm.0: new USB bus registered, assigned bus number 5
ohci-brcm ohci-brcm.0: irq 68, io mem 0x10480400
ata2: SATA link down (SStatus 0 SControl 300)
hub 5-0:1.0: USB hub found
hub 5-0:1.0: 1 port detected
ohci-brcm ohci-brcm.1: Broadcom STB OHCI
ohci-brcm ohci-brcm.1: new USB bus registered, assigned bus number 6
ohci-brcm ohci-brcm.1: irq 69, io mem 0x10480600
hub 6-0:1.0: USB hub found
hub 6-0:1.0: 1 port detected
ohci-brcm ohci-brcm.2: Broadcom STB OHCI
ohci-brcm ohci-brcm.2: new USB bus registered, assigned bus number 7
ohci-brcm ohci-brcm.2: irq 73, io mem 0x10490400
hub 7-0:1.0: USB hub found
hub 7-0:1.0: 1 port detected
ohci-brcm ohci-brcm.3: Broadcom STB OHCI
ohci-brcm ohci-brcm.3: new USB bus registered, assigned bus number 8
ohci-brcm ohci-brcm.3: irq 74, io mem 0x10490600
usb 4-1: new high-speed USB device number 2 using ehci-brcm
hub 8-0:1.0: USB hub found
hub 8-0:1.0: 1 port detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
lirc_dev: IR Remote Control driver registered, major 254
IR NEC protocol handler initialized
IR RC5(x) protocol handler initialized
IR RC6 protocol handler initialized
IR JVC protocol handler initialized
IR Sony protocol handler initialized
IR RC5 (streamzap) protocol handler initialized
IR SANYO protocol handler initialized
IR MCE Keyboard/mouse protocol handler initialized
IR LIRC bridge handler initialized
Linux video capture interface: v2.00
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
ALSA device list:
No soundcards found.
TCP cubic registered
lib80211: common routines for IEEE802.11 drivers
PM: CP0 COUNT/COMPARE frequency does not depend on divisor
EBI CS0: setting up NAND flash (primary)
NAND device: Manufacturer ID: 0xec, Chip ID: 0xd3 (Samsung NAND 1GiB 3,3V 8-bit)
brcmnand brcmnand.0: 1024MiB total, 128KiB blocks, 2KiB pages, 16B OOB, 8-bit, Hamming ECC
Bad block table found at page 524224, version 0x01
Bad block table found at page 524160, version 0x01
nand_read_bbt: bad block at 0x000000e60000
nand_read_bbt: bad block at 0x000007ec0000
nand_read_bbt: bad block at 0x000012960000
nand_read_bbt: bad block at 0x000013260000
nand_read_bbt: bad block at 0x000022240000
nand_read_bbt: bad block at 0x000029b00000
nand_read_bbt: bad block at 0x000031aa0000
nand_read_bbt: bad block at 0x00003a9a0000
Creating 4 MTD partitions on "brcmnand.0":
0x000002700000-0x000040000000 : "rootfs"
0x000002700000-0x000040000000 : "rootfs(redundant)"
0x000000200000-0x000000900000 : "kernel"
0x000000900000-0x000000b00000 : "mac"
UBI: attaching mtd0 to ubi0
UBI: physical eraseblock size: 131072 bytes (128 KiB)
UBI: logical eraseblock size: 126976 bytes
UBI: smallest flash I/O unit: 2048
UBI: VID header offset: 2048 (aligned 2048)
UBI: data offset: 4096
UBI: max. sequence number: 4
UBI error: vtbl_check: bad CRC at record 3: 0xf116c36b, not 0xf116c336
UBI error: vtbl_check: bad CRC at record 0: 0xdfa5fcfb, not 0x56108247
UBI error: process_lvol: both volume tables are corrupted
UBI error: ubi_init: cannot attach mtd0
VFS: Cannot open root device "ubi0:rootfs" or unknown-block(8,1)
Please append a correct "root=" boot option; here are the available partitions:
1f00 1008640 mtdblock0 (driver?)
1f01 1008640 mtdblock1 (driver?)
1f02 7168 mtdblock2 (driver?)
1f03 2048 mtdblock3 (driver?)
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(8,1)
Rebooting in 180 seconds..
Some bad blocks in the flash memory are present in every Duo2 and in any other device using flash memories.
This is the reason why a bad block table exists.
BCM74250012
M0
M1
01CZL2=1
LLMB=0000C000
BP=02000000
L2Cfg=1E7AD627
L2Buf=77707711
BrCfg=F01C200E
BrMod=02800801
BrZp0=44000000
BrZp1=00002000
CPU speed: 1305MHz
DDR Mode: DDR3
Boot Device: NAND
Total flash: 512MB
ETH0_PHY: RGMII
ETH0_MDIO_MODE: 1
ETH0_SPEED: 1000
ETH0_PHYADDR: probe
SCB CLOCK = 277MHz
Initializing USB.
CFE initialized.
checking usb
No Priority Usb
checking front key
Zone PFN ranges:
NR_IRQS:160
Brought up 2 CPUs
TCP reno registered
loop: module loaded
ALSA device list:
Seems there are some errors ... I suggest to use this log to request a warranty check of your unit.
Yes i know that bad blocks are present, but you have obviously missed the bit where it says the bad block volumes are corrupt and can't mount rootfs because of unknown blocks....
p.s. @angelofsky1980 seems the unit will have to be replaced which is going to cause me loads of hassle as i don't think the reseller is being very helpful, i was hoping some clever b'stard would be able to help me correct the corrupted volume tables or help me reset the rootfs load secor or something...
You can only reflash your box with latest OpenVuplus 2.1 image from http://code.vuplus.com and hope all will be corrected but I'm not sure you solve the problem.
BCM74250012
M0
M1
01CZL2=1
LLMB=0000C000
BP=02000000
L2Cfg=1E7AD627
L2Buf=77707711
BrCfg=F01C200E
BrMod=02800801
BrZp0=44000000
BrZp1=00002000
CPU speed: 1305MHz
DDR Mode: DDR3
Boot Device: NAND
Total flash: 512MB
ETH0_PHY: RGMII
ETH0_MDIO_MODE: 1
ETH0_SPEED: 1000
ETH0_PHYADDR: probe
SCB CLOCK = 277MHz
Initializing USB.
CFE initialized.
checking usb
No Priority Usb
checking front key
Zone PFN ranges:
NR_IRQS:160
Brought up 2 CPUs
TCP reno registered
loop: module loaded
ALSA device list:
hello
i have a friend's (one week old) duo2 with a very similar issue ( i haven't logged the boot) : after a flash the box hangs with the cfev2 message, and after that i cannot turn on the box: always a white little square shown on the diaplay
after unplugging the box from the main supply for some time, it starts but still hangs afterr a while
is it an hardware problem?
ps
tested with latest bh and the latest 2.1 build
Yes it is a hardware problem, I sent mine back to Vu+ In the UK and they couldn't fix it so they supplied me with a new one (Thanks Julian).
