Decode multiple channels using CI/CAM Pro cards?
Lagoni
I have a VU+ UNO 4K SE (DVB-C) running the latest BH image.
I use a Neotion Viaccess card (dual) to decode the encrypted channels and I'm only able to decode 1 channel, but the card should be a dual version? (I have tried both Multi/Auto in the CI setup but no luck).
I then read somewhere that I need to use a "Pro" version of the card and I found the Neotion Viaccess PRO 8 which (according to spec) should be able to decode 8 channels in pralallel.
Can anyone confirm if this will work and that it is supported?
Thanks.
