"Decoding" info bar - what means those letters?
LassuPC
Hi!
Maybe it's a lame question, but I have no idea what are the letters on the right bottom corner of the screen, on info bar. I have google-it, but no answers. Does anybody knows what are these symbols?
https://ibb.co/TH4M87J
ps. cannot insert picture, beacause I am new, no 30 posts ...
OK, thanks!
So:
B= Biss ? / Betacrypt?
I= Irdeto
S= ??
V= Viacces ? / Verimatrix ? / Videoguard?
N= Nagravision
T= ??
CW= Cryptoworks
ND= ??
CO=Conax
BU= ??
PV= PowerVu
I guess.
(What about the others? / Accessgate, Alphacrypt, FTV, Compel , Panaccess, RAS..../)
I suppose S=Seca, T=Tandberg, ND=NDS, BU=Bulcrypt, but I'm not totally sure as I haven't searched for them and just guessed for many of them. Maybe you can do it yourself. ;)
I am a bit confused, beacuse when surfing between channels, generally are more than one highligted, maybe there are combination of these that refers to somewhat...
This shows which coded systems are in use ,there is only one usually green that you decode
with your card.But it depends on the decoding method.
you mention other coding systems?
Not all coding systems are present in the OSD information block.
Only those shown.
