Default audio volume after restart
KFL
I have switched RCU to control volume on TV, because it is more comfortable for my family. After restarting(deep standby) my UNO BH173 is always audio volume set to 20. It corresponds to line "config.audio.volume=20" in file "settings". How to change it to 60? If I change it to 60, after restart is here 20 again.:confused:
1.Solution found: telnet-init4-edit-init3-reboot (found in other topic) - I did not try, you try it self!
2.I have upgraded to BH178, which works without problem.
