Default behavior of zap timer
luckyluke2
Hi to all,
I want to submit you a question, there is a way to modify a specific default behavior?
In the specific case when I create a timer with the zap option, the default is to set an end time, and if I choose the right option I can specify that the end time is not necessary.
Can I modify somethin to have the default behavior of the zap is without end time?
Thanks in advance, regards
P.S.
I'am still using the Black Hole Vu+ Uno v.2.0.6
