Default Black Hole Vu+ Duo v. 1.4.6 skin problems
Didi
I want to point out the fact that there is a problem with the default skin, hoping that maybe I will be helped to solve it.
The new image is excellent, with a beautiful default skin, but which unfortunately causes a problem for me: when playing movies with media player, the subtitles do not display diacritics (Romanian characters).
After installing a different skin, Army UnicaHD, it displays subtitles correctly:
I would like to ask especially Mr. Army to help me solve this problem because I want to use the image's default skin which is one of my favorites, as PureHD which unfortunately cannot be used for the latest images.
Any help would be much appreciated, thank you!
I have solved this problem by changing the font to "Army_Regular_L.ttf" in skin.xml.
hello, i have the same problem, i found the *font's lines* on the font section of the skin.xml , but which line from the fonts do i have to replace with *Army_Regular_L.ttf* ?
