Default language used for streaming
Nick Kiley
Is there any way to configure the web streaming so it defaults to the same audio language I've configured on the box? I have set up three auto-selections using the audio configuration and they work fine when I use the box as normal - it's just when I try to stream that it uses the default audio and I then have select the correct one, in VLC, for example. Thanks in advance.
I think that it's a VLC configuration issue not BH. I don't use it (VLC ;)) , sorry, I can't help.
Thanks paolino - that did get it working, appreciated. However, is there a more generic way of accomplishing this at the server end - i.e. make the box default to a specific language audio stream... FWIW, VLC appears to always play stream 1 - is there a way to swap the audio that's being served up so my selection is always sent as the first stream, even though is may be the third in the actual stream? I hope one of the developers sees this...? It'd surely be a worthwhile feature to implement, IMHO.
It's too complicated request, I can't understand. Explain in simple way.
Sorry autolanguage for subtitles and streaming is not supported in official Vu+ git and the approach ok Black Hole image is to not make these kinds of structural changes.
Yes we have implemented standard audio track autolanguage due too many users requests but there is not plan to implement it for subtitles and streaming in the near future because we prefer to wait for Vu+ implementation.
If you need this feature you can use Pli and Pli based images.
