Default media player
vajkooo
I would like to ask you for help. I used the openVix and yesterday I changed it for the blackhole. I used in the openVix default media player but if I push the button for media player which I used in Vix then opens media player but it doesn't work. There is nothing but I can't change anything or moving in the menu. Is there possible install the media player from openVix?
Thank you and have a nice day.
Now I understood that the R button on the remote control is for recording in the blackhole. Can I install media player from vix to blackhole? Or can you suggest alternative for that player? I need something simply.
Thank you.
Thank you.
No. Mediaplayer is embedded in image.
