Delete installed picons ?
What do you mean by "some are not working"?
If you don't see them in the infobar or elsewhere and you see the "BH" logo instead, it means there is no picon for that channel.
If they are too large, it's another story.
Installed picons via BH server. How do delete them as some are not working ?
Or they have not the right attributes ( must be 644 ). This, you can check by FTP. Select "alll of them" and set the attributes to 644.
You dont answer my question in which folder are the picons ? iF i WANT TO DELETE ALL PICONS where do I find them.
Some channels dont have picons some do which is ok.
I dont have a usb stick or HDD installed. The box is a duo2
The location must be:
/usr/share/enigma2/picon
If you haven't any device for handle it.
Use an FTP tool ... and navigate to the mentioned location ... select all them ... and delete it.
CAN I INSTALL PICONS FOR NILESAT 7W AND BEDER 26 E
You can install all picons you want, if available.
But next time, please don´t write only in capital letters. Writing only in capital letters is not good for reading and is the same of screaming. ;)
Hola, Iam in /usr/share/enigma2/picon how can i select all them? thank u crack.
