Deleting satellites
amine2010
Hi All,
Please i need your help.
I deleted by error some satellites and i couldn't recover them even i put a new satellite.xml in etc/tuxbux and etc/enigma2.
Many channels was deleted these is only this sign <n/a>.
Any help will be appreciated.
Thanks
I've had the n/a symbol before, in my bouquets, and all I had to do was re-scan them in. Your problem sounds different, and to solve it we need more information, regarding your satellite setup, and your tuner configuration.
Do you have a motorized system?
Are you using Diseqc 1.2 or Usals?
If a fixed dish system, with multiple LNB's, then which satellites can you receive?
I usue motor and all satellites are in A tuner but someone else in the house changed something.
Thanks for the reply
Are you suing Diseqc 1.2, or USALS, to locate your satellites?
Do you have a 36v motor, so you use a V-Box II, connected with 4 wires, or a smaller motor that just uses your coax cable?
(n/a) means there is no feed for those frequencies.
What kind of Tuner configuration U have now?
Have U made any backup?
I have had the n/a display when the satellites.xml changed, listing 5E, which I'd previously scanned in the channels, changed to 4.9E, or even 4.8E, the same with 0.8W, and 1W.
You also get it when channels have been removed, or changed transponders, but with so many, I suspect the former, rather than the latter, to be the case.
Please post back with more details.
If you have the list of channels you use and did not touch anything.
Load this list of channels and reset the receiver completely.
You restore the channel and satellites ratio of the file satellites.xml
You do not have to touch anything else.
If you touched and / or deleted satellites from the satellites.xml file, you will have to use an older one.
Satellites.xml only in etc/tuxbux, Restart interface/restart GUI to read the new one.
Si tienes la lista de canales que usas y no tocaste nada.
Carga esta lista de canales y reinica el receptor completamente.
Restauras la relacion de canales y los satelites del fichero satellites.xml
No tienes que tocar nada mas.
Si tocaste y/o borraste satelites del fichero satellites.xml, tendras que usar uno mas viejo.
Satellites.xml solo en etc/tuxbux, Reinicia interface/reiniciar GUI para que lea el nuevo.
You might also want a website to create a new satellites.xml file: only you need to do is looking for
satellites.xml generator
in your browser search engine. (It's not possible to post external URLs, otherwise I would do it).
