Device Manager and Permanent Timeshift not working
scousemicky
When I click on device manager the screen quickly flashes then goes back to the menu. I then have to press exit to get out. It's as if device manager is there but not showing on screen, if you get what I mean. Any ideas how to fix it so I can get into device manager?
I wanted to go into device manager to check hard drive was mounted because every time I install permanent timeshift, it crashes the box, reboots and keeps crashing/rebooting in a loop. So I've deleted it via FTP.
I'm just about to take my hard drive out nd see if device manager works then as it's an old 2.5". Maybe thats causing the problems?
Image is Open Black Hole Vu+Duo2 UK Ready Backup By master G.
Thanks
Thanks
No support for backup images!
