Different channel lists in Duo2
Gigantone
Scanning more satellites with Duo2, a single channel list is created. Is it possible to create different lists based on different satellites? In other receiver, pressing SAT key on remote control you can view a satellite list, select the satellite you want and browse only all channels stored in it. What about this feature in Duo2? Thank you.
Enigma2 uses their channel system to store informations.
You can see channels divided by SAT pressing the Green key into channel list but if you mean to use phisically different lists for every satellite, the answer is NO
