Different storage locations
ysee
Is it possible to record the "Daddys" programs to a different location than the default storage. However, the same hard disk.
You can use the plugin "Suomipaeka v1.0.1" and make folders on the harddisk.
Then you can choose these folders when you make a timer
That's all you can do with
System >> Recording paths
There you can specify where you want to record .
To be able to record on different locations with timer or direct
you have to make different locations >> different folders.
When you're in the Recording Paths panel >> Default movie location >> OK >> Menu button >> 1 (switch to filelist) >>Menu>>
you can make directory
remove directory
add bookmark
and switch to bookmarks.
So you first make directory (if you not have)
you add directory to the bookmarks.
Now you can use the same bookmark (directory) for recording.
in the same way you can make different directory for instant record ,timer record etc
You can also from Timer entry panel
Location>>OK>> select location for recording make the same
as well as from Recording Paths Panel
  • Like
Reactions: KFL
