Direct streaming to TV on the LAN
fcxpress
Hello all VU+ lovers,
I own a VU+ solo and I consider buying an ultimo.
Does anyone know if it's possible to stream directly to a TV with an ethernet plug on the same lan as the VU+ ?
I know how to stream via the web GUI to VLC on a computer and it works pretty fine but that's not what I mean.
What I mean is the following: Your TV is on the same LAN as your VU+ and just by pressing a button on the remote control of the LAN TV, you can zap channels on the VU+ and stream them over the network from the VU+ to the TV without using any computer.
If such a thing is possible, do you know of which TV has got that feature ?
Is such a thing also possible with multimedia player (Dune HD Max, Popcorn hour A-300, etc.) ?
