What do you mean by "dial switch"? The power button on the front or the one on the back? I don't think so.
Anyway, when my daughter was very little I decided to put every devices up to a shelf behind the TV... It was the safest solution.![]()
Hello,
Is it possible to software disable the dial switch on the Vuplus Duo? I've got a problem because my 1 year old child likes the play with any. Thanks in advance for any kind of help.
Greetings
