diseq in vu+ solo
freeidea
i have vu+solo blackhole connected zith 2 dishes throught a 4 in 1 swith i use input 1 and input 2(lnb1 ,lnb2),one LNB1 for badr 28E,and second hotbird LNB2,in tuner configuration i use the folowing setting:
Uploaded with ImageShack.us
first time it worked,but after it take a time to show hotbird channel
now i got only one sattelite and i dont know why ?
shouldn't it be input 2 for hotbird (uncommitted diseqc command) if you use lnb2 and 'no' for committed diseqc command for both sat positions??
BTW what switch do you have?
From other point of view if it was working before and has stopped the answer is so simple - faulty switch, isn't it?
what's going to happen if you will use simple configuration with diseqA/B/C/D?
I thought your switch is more complicated - but it looks like it's standard one - uncommitted commands are not required.
