Diseqc 1.1 with Solo SE V2 Dual DVB-S2
Poune
Hello,
I've just received my Solo SE V2 Dual DVB-S2 today and I can't configure Diseqc 1.1 with Open Black Hole ... I have 8 LNBs : 2 X Spaun SAR 411 F (commited) on a Spaun SUR 420 F (Uncommited) ... It's OK pour the 4 first LNBs (Input 1 on the SUR 420 F) but no signal for the 4 others on Input 2 ... I have the same config on my Azbox (OpenPli) and it work ?
Is the dual DVB-S2 tuner Disecq 1.1 compatible?
Thanx !
Have you tr4ied different settings, on LNB, Diseqc 1.0, and Disecq 1.1?
Yes, I tried others combinaisons ... I also change the mode switch on the Spaun SUR 420 F (mode 1,2,3) ... No result :( Someone who have the Single DVB-S2 tuner version can say if Disecq 1.1 + 1.0 work?
Hello,
I continue my searches for my problem. It seem that the dual tuner DVB-S2 sends Diseqc 1.1 commands to the Spaun SUR 420 F ONLY with Tuner B (because I heard the 'click' in the switch, with repetitions, but it can't succeed to switch from input 1 to input 2,3,4)
Tuner A is very sensitive : after changing configuration a need unplug the cable and replug and changing from service to another to have signal?????
Is it a problem in the NimManager.py ???
Thanx
