DiSEqC cannot switch on inputs 3 and 4 on Solo4k
Pixs
Hello,
I have a problem with my Vu+ Solo4k using the latest Black Hole image.
My tuners A and B are configured with a DiSEqC switch with for inputs:
- A: 13E
- B: 19.2E
- C: 23.5E
- D: 28.2E
Tuners A and B are working normally on inputs A and B.
But when I switch to a channel on inputs C or D nothing comes up.
The signals bar stays at N/A and the tuner letter does not "light up".
Any ideas of what could be wrong?
Thank you for your help.
First of all, describe your LNBs equipment, to be sure: do you have 4 different LNBs to get those satellites or do you have any combo LNB?.
Secondly, post the screen shot of your tuner settings.
Third, don't use the word INPUT for the satellites you have, because INPUT is usually used for the two tuners' INs you've got in your Solo4K. Or do you have only one tuner in your Solo4K? Be precise.
Thank you for the hint.
This was software related.
I did a fresh Black Hole install and this was fixed.
I just upgrade software into 3.0.5K and reach the same problem like "Pixs" - before everything was OK, where is a problem? With new software?
Well... spoke too soon.
Updated to 3.0.5K and the problem is back again.
BUT there is also a descramble problem.
I was on BBC Two then zap to an other channel and the two feed seems to be mixed.
It is a exemple with FRANCE 2 but the behaviour is the same with other channels even FTA.
