Diseqc problems (does not switch between sats)
Gerg
Hello,
I have a strange probem with a newly installed BH 2.0.7 on a Vu+ Duo (chipset 7335), installed 2.0.3 and upgraded to 2.0.7.
Usually it does work well, but sometimes I simply cannot change from one sat to another. It can still change channel on the sat I am currently tuned on, but when I want to change to another channel on an other sat it gives me nothing. The SNR is 0 and no sound or picture. If I keep trying sooner or later it will give in and start to change channels normally. It seems resatring ***** does solve the problem though. I do not see the connection between the ***** and the diseqc commands, but it helps to restart *****.
On tuner 'A' I have a 10 port uncommitted diseq (advanced setup - input 2 to 6) on port 'B' a 4 port diseq (LNBs on A,B and C). I tried to set diseqc repeat, high voltage it does not make any difference.
I used to have ViX on it until recently when I decided to give BH a try (ViX had stability problems), but never encountered this behaviour.
I would appriciate any help that can solve or help to identify the source of this probelm.
There is a diseqc test plugin which seems not working either together with fancontrol2, but they are not so important.
Thanks, Gerg
Hello,
Thanks, Gerg
So nice... READ BOARD RULES PLEASE!
Banned for 1 week.
