Try this:
Enigma2 8 DiSEqC configuration
Configuration Mode = advanced
Satellite = Satelite (Chnage satellite name here)*
Voltage mode = Polarization
Tone mode = Band
LNB = LNB 8 (Change LNBs 1-8)*
DiSEqC mode = 1.1
Toneburst = None
Committed DiSEqC command = none
Fast DiSEqC = no
Sequence repeat = Yes
Command order = uncommitted, committed, toneburst
Uncommitted DiSEqC command = Input 8 *(Change LNB input here 1-8)
DiSEqC repeats = none
LOF = Universal LNB
Increased voltage = no (yes, only if you have very long cables)
Polarity = Auto
* change this only
This should work, there are other alternatives to the DiSEqC Setup also, but i think this is the most straightforward.
