Display Episode’s Number in PVR Mode
bumperbee
Hi Everyone, I have a Duo2 using OpenBlackhole image. In every recorded program, the name & description of the show is capture correctly and is display accordingly in PVR mode. This feature is great and it is even better if the episode’s number could also be capture and display together either in the name or description. I sincerely wish if this could be done because it is very inconvenience to play the program (series) to check the episode number, and worst of all is some of this program is not displaying it at the beginning of the program. Thanks very much
I had already mentioned in my 1st post, it is very inconvenience to play the series show to check the episode and worst of all is some of it do not display the episode number at the beginning of the show.
Hi Thomas67, thank for the suggestion. I had tried it before and it is for usage in Europe.
Hi to All Developers of OpenBlackhole, I truly understand it is not a critical matter.
I was only hoping it is not complicated or a tedious works, and if it is so, then I sincerely wish it could be done during your free and comfortable time. Thanks very much
Features and functions like this should NOT be added to an image to make it heavier for every users: these functions are typically plug-ins. Anyway, I don't understand why you don't want to simply edit the filename by OpenWebInterface: it's fast, effective and... free from any extra flash use.
You have everything you need, included the extra info about the episode.
When PVR button is pressed and a certain series is selected, 2 to 5 sentences consisting of at least 100 alphabets & numbers had been captured and displayed. So I strongly feel there is not much different by capturing and displaying together in description, another, for example: “Ep50”, 4 or 5 alphabets & numbers.
