birdman99
As i mentioned in a previous post ive been using 1.7.2 Blackhole with 95 percent success for months now and couldnt help feel curious of the newer images of blackhole,ie 1.7.8  and if there would appeal to me.
Ive always had problems with the epg mainly been that the hdd would loose itself and flash memory would appear as unsuggested in configure Epg and the thing would just stop working,in the old image i would mess around for a while and get it back, the epg restore would never work so this was the only way i could ever get it back.
I basically lived with it because it was a small price to pay for such a great image.
Last week i placed a post on here about this and asking should i try the new blackhole.
I was told to try it which i did but have now relized the epg on this image does all the above but cant even be restored so unless there is any ideas or fixes which i dont think there is after seeing loads of other posts about the same problem i think i have no alternitive to go back to 1.7.2.
I just wanted to say what a shame i think it is that such a great image has been let down by the same problem but is unusable unlike the older ones.
A fix in the next image is all i can hope for..... back to 1.7.3 i go
