Divx, Xvid laggs
RedCat
Hello
I try some BH images, now I use 1.5.x image, but lot of divx and xvid are laggs. Can u fix this problem, or it is hardware problem?
Hello
Without some infos about your media file, it's very hard to report the correct debug infos to Vu+ Team.
Hello I am using BH since 3 Weeks and would say that for me this is the best Image.
I used Pli for years, tested a lot of other images. By the way, Pli with its dayly updates is very good .... and videos like avi and divx, things you can download with multimediathek made by homey can be played very well.
The same videos dont work on BH162, freez sound continous, no sound video continous. MP4 works fine.
Please gimme that video - here is the big different to Pli
Are there any updates, new drivers I haven´t install yet? :shocked:
I've tested some media files and I haven't big problems to play it.
If you post some infos/reports of files who don't play correctly, we can make tests and, if problem occour after tests, we can study a solution.
