Does somebody use Dreamdroid (Android)
correction: working now but unable to play video. Maybe because I did not setup the <optional> streaming server? And in that case how do I set it up?
Its working fine with my motorola milestone and galaxy tab. It will work on any android if properly configured and Vu-Duo rom supported.
If You are reffering to video streaming You need to install proper videoplayer on Android device itself to be able to stream content to it.
It can be also requred to mount vuduo share/harddisk in android device to be able to watch recordings.
As an update to my previous post - VLC is now available on Google Play. VLC can play stream From Vu+! In combination with dreamdroid its perfect multimedia companion.
Remember to set and enable WiFi in Your phone/tablet to be able to connect to Your local Vu+
