doubled settings
casppir
i usually download settings from the BH server. the problem is that when i tried to download and try another setting the old one was not deleted. so i have two settings with a very long list with 2 of each entry.
how can I delete them?
how can a setting be deleted with the remote control or DCC?
Just wait for the new image because you`ve to flash again :dance: just kidding.
With the remote, just go to your channel bouquets as you normally do, scroll to the one you want to delete and press the menu button and pick your choice.
If you`ve a personal backup, you can use that.
thanks for the reply. is there a close release of our favourite image?
is it possible to delete all the settings? once 4 all
You can find the files in /etc/enigma
blacklist, whitelist, lamedb, bouuets, userbouquets
New image i can`t tell you, because i know as much as you about that.
