Doubts Vu+Uno with .mkv Blu-Ray
Master87
Hi,
I shared (nfs mount) an blue-ray movie to test my vu+uno.
When I go experience vu+uno, the film does not appear in media player. I've tried others mkv and appear and possible to play.
MKV OK:
General
Unique ID                        : 250960571675566692965985816505460108149 (0xBCCD3F7BF2C54393B4A15B8DB01EAB75)
Complete name                    : M:\shares\vu\Jennifer Lopez ft Pitbull - On The Floor.mkv
Format                           : Matroska
Format version                   : Version 2
File size                        : 72.5 MiB
Duration                         : 4mn 27s
Overall bit rate                 : 2 278 Kbps
Encoded date                     : UTC 2011-03-11 21:01:16
Writing application              : mkvmerge v3.3.0 ('Language') built on Mar 24 2010 14:59:24
Writing library                  : libebml v0.8.0 + libmatroska v0.9.0
Video
Format                           : AVC
Format/Info                      : Advanced Video Codec
Format profile                   : High@L4.1
Format settings, CABAC           : Yes
Format settings, ReFrames        : 3 frames
Codec ID                         : V_MPEG4/ISO/AVC
Duration                         : 4mn 27s
Bit rate mode                    : Variable
Bit rate                         : 1 819 Kbps
Maximum bit rate                 : 40.0 Mbps
Width                            : 720 pixels
Height                           : 304 pixels
Display aspect ratio             : 2.35:1
Frame rate                       : 23.976 fps
Color space                      : YUV
Chroma subsampling               : 4:2:0
Bit depth                        : 8 bits
Scan type                        : Progressive
Bits/(Pixel*Frame)               : 0.347
Stream size                      : 55.2 MiB (76%)
Writing library                  : x264 core 112 r1867 22bfd31
Encoding settings                : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=6 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / slices=4 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=2 / weightp=0 / keyint=24 / keyint_min=2 / scenecut=40 / intra_refresh=0 / rc_lookahead=24 / rc=2pass / mbtree=1 / bitrate=1819 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=40000 / vbv_bufsize=30000 / nal_hrd=vbr / ip_ratio=1.40 / aq=1:1.00
Color primaries                  : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics         : BT.709-5, BT.1361
Matrix coefficients              : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio
Format                           : Vorbis
Format settings, Floor           : 1
Codec ID                         : A_VORBIS
Duration                         : 4mn 27s
Bit rate                         : 500 Kbps
Channel(s)                       : 2 channels
Sampling rate                    : 44.1 KHz
Compression mode                 : Lossy
Stream size                      : 15.9 MiB (22%)
Writing library                  : libVorbis 1.2 (UTC 2007-06-22)
MKV Not OK:
General
Unique ID                        : 210223115917398639248001635178858648730 (0x9E277FD855EFF2E8907B2ACCAF43949A)
Complete name                    : M:\shares\vu\Fast.Five.2011.1080p.Bluray.x264.AC3 - UpPTMSNM\Fast.Five.2011.1080p.Bluray.x264.AC3 - UpPTMSNM.mkv
Format                           : Matroska
File size                        : 9.76 GiB
Duration                         : 2h 10mn
Overall bit rate                 : 10.7 Mbps
Movie name                       : 50201 track_4113
Encoded date                     : UTC 2011-10-02 00:52:24
Writing application              : mkvmerge v4.6.0 ('Still Crazy After All These Years') built on Mar 10 2011 02:50:32
Writing library                  : libebml v1.2.0 + libmatroska v1.1.0
Video
Format                           : AVC
Format profile                   : High@L4.0
Duration                         : 2h 10mn
Bit rate                         : 10.1 Mbps
Maximum bit rate                 : 25.0 Mbps
Width                            : 1 920 pixels
Height                           : 1 080 pixels
Display aspect ratio             : 16:9
Color space                      : YUV
Bit depth                        : 8 bits
Bits/(Pixel*Frame)               : 0.203
Stream size                      : 8.98 GiB (92%)
Writing library                  : x264 core 114 r1924 08d04a4
Encoding settings                : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=10081 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=25000 / vbv_bufsize=25000 / nal_hrd=vbr / ip_ratio=1.40 / aq=1:1.00
Audio
Format                           : AC-3
Format/Info                      : Audio Coding 3
Mode extension                   : CM (complete main)
Codec ID                         : A_AC3
Duration                         : 2h 10mn
Bit rate mode                    : Constant
Bit rate                         : 640 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Side: L R, LFE
Sampling rate                    : 48.0 KHz
Bit depth                        : 16 bits
Stream size                      : 597 MiB (6%)
Anyone can help me about this? I do not understand much of codecs, their difference, I was just to test the box.
Regards
