If you downloaded from BH image server
you can unistall in BH image Uninstall Panel[/quote
there only my ***** in there does this mean all the things iv tried to download have failed.... cheers
sorry if i sound stupid but what am i looking for in system info all the clocks are pointing south and everything reads 0%..... cheers
Hi ,
I have the same problem.
I want to install plugins from server in software management - manage extensions.
after installing the box show me a message "installed,upgraded or removed 0 packages with 0 errors"
after restarting nothing new in my plugins or menu.
I'm using 1.7.8 on solo and have 17% free flash
Thatbks for your help.but what for the sofware managent is?is there any way to fix this issue?Use BH image server for downloads
green button>>yellow button>>Addons Download Manager
thanks I think the problem is from powerThis is not an issue as Black Hole cannot be updated online. Software managment works for official image, or BlackPole.
If you want to connect several devices on usb-hub, use MountManager to mount your devices. Do not forget to use an external power supply to your hub, especially if you want to connect a hard disk as the current provided by the receiver to the usb socket is very limited.
