Dreambox edit won't connect to duo plus
Sheppy100
Trying to connect to vu+ duo box via dreambox edit but it just refuses to connect, I just get a spinning circle while it tries to connect ( or test the ip connection) and that's it, doesn't stop after a certain amount of time telling why it won't connect.
The IP address (192.168.1.13) is definitely correct
Tried user as:
Root
Vuduo
have tried password as :
Leaving blank
Password
Dreambox
Vuoplus
If I try to connect through an iPad or pc with just the IP address connects no problem so assuming the configuration of dreambox edit isn't right somewhere....
Thanks for advice in advance
Drew
