dreamboxEDIT 5.0.2.0 [Download]
ikossan
Video Tutorials:
Part 1 ( basics ) : http://www.youtube.com/watch?v=NOdybaTm6mc
Part 2 ( advanced features) : http://www.youtube.com/watch?v=JZwdspaoqbE
Part 3 (new features) : http://www.youtube.com/watch?v=KTFBNAQExqg
version date : 02-05-2012
Changes in 5.0.2.0
- added configurable background color for transparent picons
- added transliteration support for cyrillic letters (only russian)
- added transliteration support for greek letters
- added option to enable/disable transliteration
- fixed some problems with very long servicenames
Changes in 5.0.1.0
- added new hints in main list, now with bouquet references
- fixed application closing after canceling
- fixed error message after dropping service on current bouquet
- fixed main service list refresh after selection of another bouquet
Changes in 5.0.0.3
- changed QuickFTP buttons to avoid further confusions
- fixed hiding QuickFTP buttons if disabled in options
- some minor fixes
Changes in 5.0.0.2
- fixed streaming for WebInterface 1.7.0 and higher
Changes in 5.0.0.1
- fixed compatibility problems when running dreamboxEDIT under wine
Note: skinning support is automatically disabled, Wine 1.3.34 or higher is mandatory
- some language file updates
Changes in 5.0.0.0
- added completly new GUI with skinning support
- added transparency to crypto icon in main service list
- added transparency to dummy picon in bouquet panel
- added configurable color marker for selected services
- added proper handling of renamed alternatives
- added warning message if multibouquet is disabled on your dreambox
- added signal strength indicator
- fixed renumbering channel numbers after using "sort alphabetically" from context menu
- fixed when sorting by frequency now also sorting by polarisation is applied
- fixed problem with missing objects (service counter, profile selection)
- fixed cut&paste services with alternatives
- fixed saving of current profile when options panel is closed
- integrated language tool (Help -> Language Tool)
- removed LanguageTool.exe from installation package
- removed outdated help files
- language files updated
- some minor fixes
The the following features are only supported on genuine Dreamboxes with Enigma2-Images based on Release 3.2 or higher
- full support for filtering of encrpyted services is now enabled
- full support for streaming services in userbouquets
- added video streaming support
Note: VLC 1.1.11 or higher is required, the installation directory is detected automatically, if you are using
a portable version set the VLC installation directory in the options panel.
- added support for taking snapshots of currently played stream
Important:
Filtering behaviour has changed in DreamBoxEdit v4 and above:
Use enhanced filter expressions (SQL style):
% as substitute for zero or more characters (e.g. %sky% shows all services with "sky" in name),
_ as substitute for exactly one character (e.g. _sky_ in package filter shows all services of provider "BSkyB")
\ as escape character (e.g. %\%% shows all services with "%" in name)
dreamboxEDIT creates default values for all options.
It's important however to check the various settings on the options panel.
The most important setting is the profile for a Dreambox that specifies both:
- the network settings needed to contact the Dreambox, and
- the paths where the settings reside on the Dreambox. Those paths must be specified correctly. They vary with
the different types of Dreamboxes (satellite, cable, terrestrial etc.). On the options panel you can set them to
the default for a specific type of Dreambox.
Tips and known issues with enigma2 boxes:
- You have to enable "Multibouquet" on the engima2 box in order to be able to see your bouquets.
Contact for bug reports and language file updates:
dhwz@gulli.com
