dreamboxEDIT 5.1.0.2
tae
Changelog:
5.1.0.0
- added support for streaming services (non TS based IPTV/Radio services) in userbouquets
- added menu for adding/editing of streaming services
- added video streaming support for all box types
- added new filter options for only new and only locked services
- added option to re-enable the old style path selection dialog
- added configurable local picons path per profile, if no path is defined the global local picon path is used
- added deletion of temporary picon.zip after picon upload
- added new skins: Deep, iOS dark, MacOS2, Mint, NextAlpha, Subway, Toxic, Windows 8, WMP 2008, Zest
- added fix for the missing context menu in edit boxes
- added new hints (no more flickering)
- re-enabled the export of cable services/bouquets in Excel readable format
Note: re-import of cable services/bouquets is not possible, all cable services will be skipped on re-import
- fixed path selection dialog translation
- fixed timeout issue with enabled active service/volume control/signal strength display
- fixed error message while creating bouquet for one satellite
- fixed error when sorting cable and terrestrial services in the compare window
- some minor fixes
Thx dhwz
Info!
Quote: dhwz VTi-Board
Ich hoffe jetzt sind auch alle zufrieden, das Streaming funktioniert nämlich jetzt auch auf der VU+.
Ich hab also kein Problem mit VU+ Boxen wie manch einer hier mal vermutete
I hope, now all satisfied with the work that is now streaming on the VU +.
I have no problem with VU + boxes as some here once suspected (VTi-Board)
Good man, perfect Toll :thanks:
  • Like
Reactions: tae
